new idea
CLUBCARRERA
1.2tl +1.2tl one cabinet with 18" pr one crossover running parallel to tweeters for one drops main speaker to four ohm load overall
Post edited by CLUBCARRERA on
Why ohhhh why?--Gary--
just for fun to see or read what people think
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I think you have crazy idea's
but hey that what makes the world turn! check out this crazy design
http://www.parts-express.com/audio-artistry-cbt36k-line-array-speaker-pair-kit--301-980
If you can dream it ...someone will build it...well sometimes!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
http://www.mcintoshlabs.com/us/Products/pages/ProductDetails.aspx?CatId=Speakers&ProductId=XRT1K
source: http://www.stereophile.com/content/mcintosh-system
... or... at the other end of the spectrum:
http://ratch-h.com/farm.html
(no extra charge for nightmares occasioned by the mantle art or the dolls...) -
.... and now I really wish I could un-see that....Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
yeah, but the speakers are cool... and, in all seriousness, those "69 cent wonder" PartsExpress closeout drivers (PE cat. no. 269-469, Pioneer OEM) were amazingly good sounding fullrange drivers.
CLUBCARRERA wrote: »just for fun to see or read what people think
I'm one to promote experimentation. I've done some interesting things too, sometimes it was a waste of money but I always learned something from it. If you have funds and the knowledge to design the XO and select the drivers. Go for it. Who knows?
I would like to hear them.'65 427 Shelby Cobra
'72 Triumph TR-6
__________________
'88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
'86 Polk SDA CRS+
'84 Polk Monitor 10A (Peerless tweeters)
'05 HSU VTF-3 Sub (Original OEM)
'20 HSU VTF-3 Sub (three more, 100% cloned)
'93 Carver TFM-35
'88 Carver M-1.0t
'88 Adcom GFT-555
'88 Adcom GFP-555
'88 Adcom GFA-555 (upgraded/restored)
'88 Adcom GFA-555 (a second one upgraded/restored)
'05 Onkyo DV-555 media
'89 Fosgate 360 Digital Space Matrix
'89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
'91 Kenwood Basic M1D Amp
'89 Pioneer Laser Disc media
'89 Sony SuperBeta HiFi media
One PGA2310 based custom built remote volume control
Four Polk T-15's
Four Polk TSi-200's
Four Polk TSi-100's
Two Polk CS-10's -
How is this different from your other thread: http://www.polkaudio.com/forums/showthread.php?163097-the-next-sda-srs-1.2-tl
other than a few more woofers and tweeters?Home Theater/2 Channel:
dhsspeakerservice.com/ -
That is his problem, he doesn't. He thinks that removing the magnet and voicecoil from an 18" JBL woofer will net him a passive radiator.Political Correctness'.........defined
President of Club Polk -
He didn't get enough attention.Political Correctness'.........defined
It will but the cone would require some mass damping for any chance to achieve the correct response to the cabinet.
This one would be a better starting point. http://www.parts-express.com/tc-sounds-vmp-18-passive-radiator--293-684'65 427 Shelby Cobra
'72 Triumph TR-6
__________________
'86 Polk SDA CRS+
'93 Carver TFM-35
'88 Carver M-1.0t
'88 Adcom GFT-555
'88 Adcom GFP-555
Four Polk T-15's
Four Polk TSi-200's
Four Polk TSi-100's
Two Polk CS-10's -
Apparently. I'd still like to know how you're going to wire 6 or 8 woofers, and end up with a nominal 4 or 8 ohm impedance seen by the crossover.He didn't get enough attention.Home Theater/2 Channel:
Eight drivers are easy.
For example.
1) Two 8 ohm drivers in parallel = 4 ohms
2) (Two two-driver) arrays from step 1) in series = 8 ohms
3) (Two four-driver arrays from step 2) in parallel = 4 ohms -
Now do it for 8 ohmsHome Theater/2 Channel:
You said 4 or 8 ohms in post 14 ;-)
Well, as an empiricist, I know that we can get close enough.
First two configurations that come to mind.
Six woofers:
1) three in series = 24 ohm "module 1"
2) Two "module 1" in parallel = 12 ohm "module 2"
Very amplifier-friendly (nominal) load
or...
Eight woofers:
1) Two 12 ohm "module 2" above in parallel = 6 ohm "module 3" (six woofers in toto)
2) On 8 ohm woofer in parallel with one "module 3" = 3.4 ohm "module 4" ( for module 4, Rt = 1/(1/6 +1/8) = 3.4 ohm)
3) Two 3.4 ohm "module 4" in series = 6.8 ohm "module 5"
or... I can think of a couple of ways to get a nominal impedance of 7 ohms... -
I was kidingmhardy6647 wrote: »You said 4 or 8 ohms in post 14 ;-)
Six woofers:
or...
Eight woofers:
or... I can think of a couple of ways to get a nominal impedance of 7 ohms...Home Theater/2 Channel:
If you took your original formula and substituted 4 ohm drivers, and for step 3 put them in series instead of parallelHome Theater/2 Channel:
Thank god the forum update dropped the picture of the OP's abomination,
