Blackhole5
dkfreebird
I have been working on the upgrades on my 2.3tl's and am ready to install the blackhole5.Do I need to make the strips for the mids the same length for inner and outer mids or just long enough to cover to the bottom of each row?
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
Oppo 103
Pangea PC
Post edited by dkfreebird on
Just enough to go from top driver to bottom driver, 4" wide strips..
Thanks,the reason I was asking is so I can stretch the sheet with as little as waste as possible.What about the sidewalls?2 Channel
Oppo 103
Pangea PC
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
I put 2" wide strips on the side same length, but in all honesty I don't think it's needed, the back wall is where it's at..
Don't overdo it. 4" wide strips on the back wall only, directly behind the woofers. From the top of the top woofer opening, to the bottom of the bottom woofer opening.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Got it,I think I have got it to where I need to be for now on the upgrades,as much as money allows,except for the rings which I hear might be coming soon.2 Channel
Oppo 103
Pangea PC
And thanks Dave for the help on the crossover upgrades,I got kinda nervous when they didn't show up in tracking when I shipped them.2 Channel
Oppo 103
Pangea PC
No worriesHome Theater/2 Channel:
Dskip I will have some extra,I got a 24x27 sheet and it looks like I will only use a little of it and you are welcome to what you need of the rest,I will let you know what I have left this weekend2 Channel
Oppo 103
Pangea PC
If you don't need the rest Dskip I could use some to do my newly acquired CRS+'s."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
