I would of never thought you could do this.
pitdogg2
pitdogg2 Posts: 27,269
edited August 2014 in Electronics
Post edited by pitdogg2 on
    EndersShadow Posts: 17,719
    edited August 2014
    True, but we dont really know what those nifty MIT like network boxes are doing, so its very likely they may have the ability to somewhat voice the cables to the speakers.....
    edited August 2014
    True enough but if memory serves me right, The owner of Transparent was also part of MIT and the split was in regards to "how" the network boxes were going to work. His philosophy was different than Joe's so he took his and built Transparent cables.
    F1nut Posts: 51,970
    edited August 2014
    It would have to do with impedance matching. Most of MIT's interconnects include a switch on the network box, so the end user can adjust it to match the input impedance of their gear.
    F1nut Posts: 51,970
    edited August 2014
    There use to be some info on MIT's site addressing the relationship between the two companies, but it is no longer there. Anyway, the relationship as it was, for a short period of time back in beginning MIT had Transparent building their cables. That is it.
    edited August 2014
