Dreadnought Cases..
Toolfan66
Toolfan66 Posts: 16,906
edited August 2014 in For Sale (FS) Classifieds
Ok here we go!! I have already ran these on the Laser. Cases will be powder coated Black, the side panels will be Black Oxide. They will come with the holes to mount the Speakons.
I want these cases to go to those that are in the group buy first, just in case there is interest outside the group buy..
Cases will be $100 shipped.
Please post here for those interested, I know there are a couple of guys in the group buy that can't access the for sale thread, and yes I know the rules but this IMO needs to be overlooked considering the group buy.. I will make sure you guys are not over looked. Hell I guess they won't be able to read this thread anyway!! LOL!!
PM me and I will send you payment info..
Thanks!!
Post edited by Toolfan66 on
  • voltz
    voltz Posts: 5,384
    edited August 2014
    Thanks Larry I need one :)
  • Sea
    Sea Posts: 317
    edited August 2014
    PM sent, thanks Larry.
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • voltz
    voltz Posts: 5,384
    edited August 2014
    payment & address sent. Thanks again Larry :)
    nooshinjohn Posts: 25,100
    edited August 2014
    in for one Larry...
  • jonicont
    jonicont Posts: 277
    edited August 2014
    Pm sent--Thanks
    SDA 2BTL, VPI Prime, Soundsmith Zephyr MKIII, Rogue Ares Magnum, McCormack DNA 0.5 Gold, ARC LS-17se, Cambridge cxn v2, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • vmaxer
    vmaxer Posts: 5,116
    edited August 2014
    I'm in for one as well. PM later.
    Thanks a lot, I agree with you taking care of the newer guys too.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • GlennDog
    GlennDog Posts: 3,085
    edited August 2014
    I will need 3
    thanks Lar Dog . . . much appreciated
    I would like to finish one or two of these boxes with an automotive finish
    what do you recommend? Can I just sprayed over the existing?
    forgive me but I know nothing about this painting process
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • agfrost
    agfrost Posts: 2,421
    edited August 2014
    I'm in for one, thanks Larry.
    Jay
  • motorstereo
    motorstereo Posts: 2,050
    edited August 2014
    I need one to; thanks Larry
    edited August 2014
    6 cases are paid for..
  • dpowell
    dpowell Posts: 3,054
    edited August 2014
    In for one Larry.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, ADCOM GFA 7807 + 5400, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
    edited August 2014
    10 cases are paid for..
  • vmaxer
    vmaxer Posts: 5,116
    edited August 2014
    PM sent for payment info.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ZLTFUL
    ZLTFUL Posts: 5,640
    edited August 2014
    In for one...info incoming...
    edited August 2014
    PM's replied..
    edited August 2014
    14 cases paid for...
    edited August 2014
    16 cases are paid for.
    I will be picking these up from paint tomorrow, all I will be waiting for is the side panels that will be black anodized, and the hardware to put them together..
    I should end up with 4 extra cases after it's all said and done after the group buy. So no one should be left out that wants one..
    Thanks again guys for making this easy to get done..
  • pglbook
    pglbook Posts: 2,173
    edited August 2014
    Toolfan...at the risk of sounding totally ignorant...
    What is a dreadnought case?
    Thanks.
  • GlennDog
    edited August 2014
    pglbook wrote: »
    Thanks.
    You need one, if you have SDAs . . . . and it might help if you bought a 1 KVA tranny!
    There might be one floating about soon
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • pglbook
    edited August 2014
    GlennDog wrote: »
    GlennDog:
    Thanks for the reply.
    I actually have Polk SDA 2B TL speakers.
    What is a dreadnought case and what does it do?
    And a 1 KVA tranny? What is that?
    Thanks again.
  • GlennDog
    edited August 2014
    pglbook wrote: »
    GlennDog:
    Thanks again.
    The "case/metal box" houses the "tanny/tansformer" and allows you to power your SDAs with non-common ground amps
    You are a prime candidate for one!
    G
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • pglbook
    edited August 2014
    GlennDog:
    Thanks for the info and education.
    Two of the many great things about this site are the knowlege one gains and the great people willing to share their expertise.
    I run my SDA 2B TLs by a Parasound 1500A power amp which is a common ground amp so I guess I would not need a dreadnought case/tranny...but I now definitely see the reason for having one.
  • GlennDog
    edited August 2014
    "they say" that the SDA sound can be improved using the 1 KVA transformer,
    regardless of amp (common Or non-common ground amp)
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    edited August 2014
    GlennDog wrote: »
    This is very true, I was shocked by the improvement. I would never use a standard cable again..
  • vmaxer
    vmaxer Posts: 5,116
    edited August 2014
    Toolfan66 wrote: »
    You shouldn't be thanking us, we thank you. You have provided us with several improvements we could not have had otherwise.
    A big THANK YOU!!!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 49,801
    edited August 2014
    Toolfan66 wrote: »
    +10000000000000000000000000
  • nspindel
    nspindel Posts: 5,343
    edited August 2014
    Big time. A quality cable is a big improvement over the stock cable, but then the Dreadnought brings it to another level.
    edited August 2014
    17 cases are paid for....:-)
    edited August 2014
    Looks like all 20 for the group buy are accounted for..
    I still have 4 extra if someone has a need for them, if so let me know!!
    Thanks again!!!
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited August 2014
    Toolfan66 wrote: »
    Thanks again!!!
    Can you possibly hang onto one of these for me for a week? I'll know whether or not I'll have one of the transformers in the next few days.
