DIY power cables
kevhed72
For stranded wire....should the bare wire strands be solders prior to connecting to plugs? Does it really matter?
Post edited by kevhed72 on
Not with any of the "plugs" I have used -- i.e., Furutech or Wattgate.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Doug and headrott helped me with soldering when I installed an IEC inlet in my SC-05, which had bare stranded wire.
These were their instructions: "You don't want to just melt the solder with the iron. The wire and the part you are soldering must be hot enough to melt the solder, so you have a good connection. It's best to tin the wire and connector first. Melt a little on the iron, then touch that to the connection. This helps transfer heat to what you are soldering. Once the wire and the connector are hot enough, the solder will melt into them."
Edit: are these solder connectors you are using or set screw types? -
Hubel screw type. I would rather not mess with the solder unless it makes a difference....
I was originally going to go with the screw type so I wouldn't have to solder. Just ignore my nonsense above, I thought you were asking whether you needed to apply solder to the wire before making a solder connection.
NO do not solder.
Just make sure no stray wires and then check for continuity across all holes blades and pins. What you are checking with the tester is to make sure double sure no stray wire are touching another conductor at all. So no stray positive to negative or ground. Most all plugs will isolate with plastic but you never know. -
In the industrial and military areas, good engineering practice dictates that stranded wire not be solder-tinned when used with screw-head connectors. The main reason is that with time and temperature the solder-tinning will cold-flow and allow the terminal to loosen
Interesting.....thanks folks
speedskater wrote: »in the industrial and military areas, good engineering practice dictates that stranded wire not be solder-tinned when used with screw-head connectors. The main reason is that with time and temperature the solder-tinning will cold-flow and allow the terminal to loosen
x 2!!A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
And now the secret way to solder-tin stranded wire:
Strip the insulation back about 3/16 inch. Solder-tin these short exposed strands. Now strip back another 3/8 inch of the insulation. Make sure that the non-soldered strands are under the terminal. -
^ like thatHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Speedskater wrote: »And now the secret way to solder-tin stranded wire:
+1. That is how I do it sometimes, usually with large guage wire that has a high number count of very fine strands that make it difficult to insert in the terminals without coming apart. With any other type of stranded wire, I don't solder.Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
If your power cable is heating up, you have much larger issues at hand.
Compression fittings of stranded cable is usually preferred in areas that aren't going to be exposed to heat/cool cycles. This is why I chuckle at those here on the forum tinning their wires for use in Speakon connections. The stranded wire gets a much better connection through compression than if it were stuck together in the tinning process and then held under a screw.
Either compress bare strands or properly solder, but don't tin together the mess and expect a screw to hold it.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Here is a pic of the finished product....not too shabby for the first time.
Question on the 1st pic....I assumed the N on the plug was for the NEUTRAL wire and L was for the HOT, or "LIVE"....I'd hate to assume and blow something up at this point... -
Nice, clean, work!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
No assembly photos?
No photos....but I am in the process of shortening another cable for my HT, when I concluded my wire stripper tool is dull as hell. Is there any secret to keeping these sharp? I have gone through 3 now in my lifetime (2 basement finishes and numerous audio related uses) and was wondering if I just pitch these?
I have been using my strippers regularly for many years and have not had any problems. You need to start with good quality strippers. Ditto for other hand tools. I have two automatics and one manual that I use depending on type of insulation and location. The same for cable assembly and crimping, you need the right tools for the job.
The best wire stripper.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
