Just purchased Polk Audio SDA SRS 1.2TL
Those look and "sound" like the ones that were on the Gainesville, FL Craig's List.Jesus said "I am the Way, the Truth and the Life. No man comes to the Father but through Me." - John 14:6
NAD 7140, Fried Model Qs, Pioneer PD-4700 -
Yes.
Congrats. Great speakers and great price."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Congratulations on snagging a great deal and welcome to Club Polk.
Pay attention to the guys on the Forum who know what they're talking about, get those monoliths fully upgraded, and you will be as happy as an audiophile can be! I've been there and done that!
Oh, and welcome to the rabbit hole! :~)Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Thanks, I removed a tweeter says made in 89. Will remove a crossover next. So there looks to be 9 bolts holding in, Do I remove all
but the middle one? Then just pull the plate out?
*Oh crap, did not mean to uplad such a huge photo. -
me wrote:If you remove one of the front panels (do not remove the center bolt) you will find a number on the crossover, either BE2000-B or BE2000-C.
....Political Correctness'.........defined
President of Club Polk -
Ty for the extra confirmation, just being careful. Been wanting these for many years, don't want to destroy them first thing.
I can tell you that those mid-drivers have been removed before. The two wire leads should be pointing down and yours are all over the place. You should remove all the mid-drivers to check they are the proper ones in the proper place, but first pull a crossover to see which model you have.
Pulled all the mids, they are all on the correct ones and on the correct sides of the speakers. Will pull the crossover and check that later today or tomorrow. Also need to fix the problem with the broken terminal on the rear of one, which is also missing the plastic nuts that hold the wires.. Will get the tweeters eventually , Think I am going to replace them all with the RDO-198's'. The originals were the sl3000 and the guy did replace them with sl2000. -
If you pull one tweeter and note the size of the terminals you will have your answer whether they are 1.2 TL's or 1.2's. If both posts are the same size, you have 1.2's. If one post is bigger than the other, you have 1.2 TL's. That's taking into consideration that no mods were done to begin with....SDA SRS 2.3TL's
SDA 2B TL's -
They are different sizes, one wide one skinny.
In all likelihood you have 1.2 TL's. Just to be sure, can you pull an SL2000 tweeter and note the size of each wire? There should be a wide one and a skinny one. If that's the case, you have 1.2TL's without a doubt. You'll notice an immediate improvement in sound quality by replacing all the tweeters with the RD-0198's.SDA SRS 2.3TL's
SDA 2B TL's -
Yea they are wide and skinny too, I pulled them to make sure what I had.
Pulled the crossover looked but didn't see a number. Where is it usually located?
It's on that white label/sticker..
You have BE2000-C crossovers..
You stole those at $500, that's what I paid for a pair as well.. :-)
Congrats on the 1.2 TL's!SDA SRS 2.3TL's
SDA 2B TL's -
Thanks, I saw them for that price and texted the guy immediately. Hmm usually nmy luck runs the other way.
