Bedroom HT
Mikey081057
Mikey081057 Posts: 7,127
edited August 2014 in Speakers
Started putting together a small HT setup in the bedroom...It will probably be a 3.0 system, utilizing a leftover LSi7's as the mains driven by my old standby Yamaha RX-V795.... Trying to find a center channel that would be compatible and work with that EQ... There is a local LSiC here in NJ that I might consider, but are the LSi's going to be a problem for that old yammy to drive.... (really not going to overdrive in the Bedroom.).
Is there another compatible model center that would work ? I was going to buy a soundbar but have these leftovers that I decided to plug in...
Any thoughts?
Garage | Polk Monitor 5B's
    EndersShadow Posts: 17,765
    edited July 2014
    Honestly, for a bedroom I would just stick with stereo.
    Those LSi 7's should sound quite good. Maybe add a sub (or two) but for me, I had a 3.1 setup in my bedroom at one time using a set of Monitor 40's, CS1 & PSW125, and TBH it was too much.
    If I "really" want to do a movie "right" I want the bigger TV in my main room anyway, so I'd just stick with stereo.
    Otherwise as skip suggests, sell the LSi 7's and maybe look at some RTi A1's x 2 (L/R/SL/SR) and a CSi A4....
  • Mikey081057
    edited July 2014
    Saw that one...seems like a good deal and they are a bit hard to find.
  • Mikey081057
    edited July 2014
    Yeah the LSi 7's do sound good... and I could throw an MP1K sub up there... the 5's are a little too big for the space...
    edited July 2014
    Thats what I'd start with. If you still want more, then go with a 3.1 setup of RTi's or the 5 channel setup I suggested as its easier for your AVR to drive.
  • Mikey081057
    edited July 2014
    Is a soundbar good enough for the bedroom? can I add a wired sub to any of the base models?
    edited July 2014
    I would think you can, not sure how the wiring would work.
    On my Surroundbar 1000 it takes a optical input from my TV. Not sure if thats the standard......
    For my wife and I the Surroundbar 1000 is perfect for bedroom watching. She was not interested in the 2000 which was like 20 bucks more from Polk eBay that came with a wireless sub lol...
    DSkip wrote: »
    Just do a 2.1 if you've got a free sub. There is no point to get a center in a bedroom, especially when you're talking about an LSiC that could strain that receiver.
    I agree. Re-use the LSi7's and just find a cheap sub or re-use one you have already and I think you will be more than happy.
  • Mikey081057
    edited July 2014
    So I ended up taking 2 "satellite" speakers from an old RM5400 kit I had and making a center out of those by wiring them in parallel to give me a 4 ohm load and laying them on their sides, the 2 LSi 7's and the MP1K to make a 3.1 system... gonna use a PS3 as a BDP/Gaming system, cd player and network audio streamer.... and Voila......It sounds ok....the MP1K sub is the star and perhaps a bit overkill...but is sounds a lot better than the tv speakers :)
    The old RX-v795 seems to be running cool and I am not worried about blowing it... if it does... hey new toy time!!!
  • Mikey081057
    edited July 2014
    For music it definitely sounds better in 2.1 but for movies the 3.1 adds a dimension that I kinda like. I can toggle modes for now... The AVR is not so good and that is the current weak link...I remember when I was wowed by the RM5400 series... that was a long time and many speakers ago :)
  • tophatjohnny
    tophatjohnny Posts: 4,189
    edited July 2014
    If I pick up on what Dan is saying with the term "Stereo" I am on that page. I went with a relatively efficient 2 channel set up for my bedroom, and am quite happy . So many options out there. Glad I found the avenue I did. Woke me up that;s for sure,
  • oleon621
    oleon621 Posts: 178
    edited July 2014
    I guess 7.2 in my bedroom is a bit overkill
    Front- RTI A7,(powered by ADCOM GFA 5500)
    Center- CSI5,
    Surrounds- RTI 6 and Rear Surrounds- TS 15.
    TV-Panasonic P55ST50
    SUB-SVS PB10-NSD and PSW505
    Receiver- Yamaha Aventage RX-A2000
  • rooftop59
    rooftop59 Posts: 8,120
    edited July 2014
    I ran 3.1 in the bedroom for a long time, finally installed two in-ceiling speakers several months ago. Truthfully I rarely watch movies, but the wife prefers to watch tv in the bedroom and I like to experience the pretty decent surround sound that a lot of tv shows now have, and we listen to a lot of concerts on palladia with the kids. So I don't think its overkill, though my wife does think I am a little insane...
    Game Room 5.1.4:
    Bedroom 2.1
  • Mikey081057
    edited August 2014
    So this has evolved a bit... I found a cheap Yamaha TSA 6750WA (RX-V675 bundled with a wireless kit) refurb. Installed a leftover PS 3 for a BDP/gaming system. Still contemplating what would serve as a compatible yet compact center. Any Ideas?
  • Mikey081057
    edited August 2014
    And it continues.... took a drive to see fellow Polkie Devani today and releived him of the nice LSiC he had for sale..Now I have a center channel that can hang... Some may think it over kills, but in this config it really sounds great. Not a very big room so no worries about stress on the receiver... runs cool.
  • devani
    devani Posts: 1,497
    edited August 2014
    Nice to meet you too Mike.....I think center is the biggest component in HT setup.
    Devin
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • Mikey081057
    edited August 2014
    Thank you again Devin.. Everything is working out great.
    Cheers!
  • recoveryone
    recoveryone Posts: 930
    edited August 2014
    Read all of the above threads and what I didn't see was the size of the room and discription on where the speakers, TV and all the rest will be placed.
    I run a 5.1 setup in my master bedroom and I could not be happier. The vaulted ceiling adds to the widening of the sound field as the fronts and center sit 8 feet above the floor on a shelf above the main closet. That shelf holds all the components and the 39" flat screen mounts along the face of the shelf. The room measures out at 25 feet wide and 18 feet long in the main area. I use some old Optimus LX5's as rears and with that 360 tweeter on them brings out those small sounds of surrounds bring.
    Size of the room and design/layout will be the real test to see what will work best.
  • Mikey081057
    edited August 2014
    The room is actually on the small side, app 14x14... The 37' tv is wall mounted on an articulating arm with everything tilted toward the center... which is the only way it can go.... I used the Yamaha YPAO room correction and it sounds good. The LSi7's can easil fill the room and the LSiC nowfits under the TV now that I raised it by about 4". I put a lot of thought into this yesterday contemplating finding a used set of Mirage OmniSat's or perhaps a used set of DefTech small HT 5.0 speaks. This being the lowest cost option and I am very happy with it (for now) :) The MP1K is x'd over at about 80 and provides nice tight bass in this space. I am using an old set of those polk RM54XX as surrounds, and they are as they don't need to do much and they are nice and small. All in I now have a nice little BR HT 5.1 system that is networked and does everything I need it to do with around $500 invested in the refurb receiver and the LSiC... The rest were all spare parts.:)
    edited August 2014
    No such thing as overkill if you think it sounds good. I am glad your enjoying it. Its a very nice system for a bedroom!
  • recoveryone
    edited August 2014
    Ditto
