Do i set my TSX440t speakers to small or large on the receiver.
ranj
ranj Posts: 11
edited July 2014 in Speakers
I own a Marantz SR5008, with 2 TSX440t speakers (no other speakers), and no separate sub woofer. What setting should I set the receiver at please.
Post edited by ranj on
    tonyb Posts: 33,068
    edited July 2014
    Large...have you read the manual for the receiver ?
  • ranj
    ranj Posts: 11
    edited July 2014
    I have not set my receiver up yet. Should I get a separate sub though, will this ease the workload on the tower speakers and produce better sound?
    tonyb Posts: 33,068
    edited July 2014
    ranj wrote: »
    Yes, it would. However, you need to read the manual to the receiver and set it up correctly. If you want good sound anyway. Todays receivers are not plug and play like older receivers, you need to set them up and read the manual so you know what everything does and how to tailor the sound.
  • quicksilvergts
    quicksilvergts Posts: 274
    edited July 2014
    I agree. It is a "must".
    Took me about a week to understand my
    Sc1222. That darn MCACC is a bit tricky :/
    That way you are ready to adjust on the fly and like Tony said "tailor the sound"
    Cheers!
    Edit- always a good idea to download the pdf (from manufacturer website) to your phone.
    That way wherever you are, you can study (so to speak).
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    Parasound 1200 II w/ Kimber Kable HERO + 4TC
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
    "If your BOLD enough to try it,
    your BOLD enough to make it happen"
