Do i set my TSX440t speakers to small or large on the receiver.
I own a Marantz SR5008, with 2 TSX440t speakers (no other speakers), and no separate sub woofer. What setting should I set the receiver at please.
Large...have you read the manual for the receiver ?HT SYSTEM-
lsi 9's -
I have not set my receiver up yet. Should I get a separate sub though, will this ease the workload on the tower speakers and produce better sound?
Yes, it would. However, you need to read the manual to the receiver and set it up correctly. If you want good sound anyway. Todays receivers are not plug and play like older receivers, you need to set them up and read the manual so you know what everything does and how to tailor the sound.HT SYSTEM-
lsi 9's -
I agree. It is a "must".
Took me about a week to understand my
Sc1222. That darn MCACC is a bit tricky
That way you are ready to adjust on the fly and like Tony said "tailor the sound"
Cheers!
Edit- always a good idea to download the pdf (from manufacturer website) to your phone.
That way wherever you are, you can study (so to speak).Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
Parasound 1200 II w/ Kimber Kable HERO + 4TC
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
"If your BOLD enough to try it,
your BOLD enough to make it happen"
