Just purchased Polk Audio SDA SRS 1.2TL
  • Pastor Bill
    Pastor Bill Posts: 130
    edited July 2014
    Those look and "sound" like the ones that were on the Gainesville, FL Craig's List.
    Jesus said "I am the Way, the Truth and the Life. No man comes to the Father but through Me." - John 14:6
    NAD 7140, Fried Model Qs, Pioneer PD-4700
  • jgwinett
    jgwinett Posts: 30
    edited July 2014
  • tophatjohnny
    tophatjohnny Posts: 4,189
    edited July 2014
    Congrats. Great speakers and great price.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited July 2014
    Congratulations on snagging a great deal and welcome to Club Polk.
    Pay attention to the guys on the Forum who know what they're talking about, get those monoliths fully upgraded, and you will be as happy as an audiophile can be! I've been there and done that!
    Oh, and welcome to the rabbit hole! :~)
  • jgwinett
    jgwinett Posts: 30
    edited July 2014
    Thanks, I removed a tweeter says made in 89. Will remove a crossover next. So there looks to be 9 bolts holding in, Do I remove all
    but the middle one? Then just pull the plate out?
    *Oh crap, did not mean to uplad such a huge photo.
    F1nut Posts: 51,805
    edited July 2014
    me wrote:
    If you remove one of the front panels (do not remove the center bolt) you will find a number on the crossover, either BE2000-B or BE2000-C.
  • jgwinett
    jgwinett Posts: 30
    edited July 2014
    Ty for the extra confirmation, just being careful. Been wanting these for many years, don't want to destroy them first thing.
  • jgwinett
    jgwinett Posts: 30
    edited July 2014
    I can tell you that those mid-drivers have been removed before. The two wire leads should be pointing down and yours are all over the place. You should remove all the mid-drivers to check they are the proper ones in the proper place, but first pull a crossover to see which model you have.
    Pulled all the mids, they are all on the correct ones and on the correct sides of the speakers. Will pull the crossover and check that later today or tomorrow. Also need to fix the problem with the broken terminal on the rear of one, which is also missing the plastic nuts that hold the wires.. Will get the tweeters eventually , Think I am going to replace them all with the RDO-198's'. The originals were the sl3000 and the guy did replace them with sl2000.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited July 2014
    If you pull one tweeter and note the size of the terminals you will have your answer whether they are 1.2 TL's or 1.2's. If both posts are the same size, you have 1.2's. If one post is bigger than the other, you have 1.2 TL's. That's taking into consideration that no mods were done to begin with....
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jgwinett
    jgwinett Posts: 30
    edited July 2014
    They are different sizes, one wide one skinny.
  • michaeljhsda2
    edited July 2014
    In all likelihood you have 1.2 TL's. Just to be sure, can you pull an SL2000 tweeter and note the size of each wire? There should be a wide one and a skinny one. If that's the case, you have 1.2TL's without a doubt. You'll notice an immediate improvement in sound quality by replacing all the tweeters with the RD-0198's.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jgwinett
    jgwinett Posts: 30
    edited July 2014
    Yea they are wide and skinny too, I pulled them to make sure what I had.
  • jgwinett
    jgwinett Posts: 30
    edited July 2014
    Pulled the crossover looked but didn't see a number. Where is it usually located?
    Toolfan66 Posts: 18,080
    edited July 2014
    It's on that white label/sticker..
    edited July 2014
    You have BE2000-C crossovers..
    edited July 2014
    You stole those at $500, that's what I paid for a pair as well.. :-)
  • michaeljhsda2
    edited July 2014
    Congrats on the 1.2 TL's!
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jgwinett
    jgwinett Posts: 30
    edited July 2014
    Thanks, I saw them for that price and texted the guy immediately. Hmm usually nmy luck runs the other way.
