I can't notice the sda effect, am I crazy?
Bugstyvy
I'm experimenting with interconnect and having a hard time noticing a distinct difference. Am I the only one? Sounds awesome either way. A little bright though.
Mcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Pro-ject Record Player
Sony 200 disc CD Changer
Basic Wiring
60" Samsung Series 8
SDA-1.2TL
SDA-3.1TL (unused at the moment)
Mcintosh 2105
Integra Pre amp 9.8
Basic Wiring
SDA-1.2TL
Post edited by Bugstyvy on
You have them "properly spaced" and powered, right! Because if you don't do that you can collapse the field pretty easily. Also, SOME recordings have a more pronounced effect than others, so play a variety of things!
Where you sit also has an effect. More will chime in.
Do half the midwoofers stop playing when you disconnect the interconnect that play while connected?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Use this link and go to the bottom posting. This should help you out.
http://www.polkaudio.com/forums/showthread.php?55888-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-Stereo-Dimensional-Array%28SDA%29 -
Double check you have them set up correctly, left speaker on the left, right speaker on the right. Make sure your interconnect cable is good (check continuity). Check for proper SDA function. There's a section in the SDA Handbook for testing.
As cnh says, there's a sweet spot, essentially an equilateral triangle between the speakers and your listening position.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Explain in detail how you have them set up, such as how far apart, how far from the back and side walls, any toe in, etc.A little bright though.
That, in large part, would be due to that crappy, brighter than sunlight Sony CDP.Political Correctness'.........defined
President of Club Polk -
They are about 8 feet apart, I'm 10 feet from them. The phono is similar to the CD player, not a major difference. I had them 10" off the wall and since moved them to 3",Noticed a bass increase. I swapped cords from my 3.1's and still the same. It's hard to tell if there is change when I'm behind them to unplug the interconnect.Mcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Basic Wiring
SDA-1.2TL
SDA-3.1TL (unused at the moment) -
What's the distance from the outer edge of the cabinets to the side walls? Overall room dimensions? Any furniture that sticks out farther than the front of the speaker baffle? I don't consider my room setup to be "SDA optimal," but the differences with/without the interconnect are not so subtle that I feel I need to be in the sweet spot to be certain of a change.
Puzzling.
Are you getting "stereo" effects, if not SDA? That is, you haven't accidentally activated a "mono" setting on your preamp?Jay
When I used my SDA-2Bs I noticed the effect was more source dependent. Some songs I would look to the left or right wondering where that sound came from.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
WHAT SPEAKERS???I'm experimenting with interconnect and having a hard time noticing a distinct difference. Am I the only one? Sounds awesome either way. A little bright though.
1. Amp connected in PROPER POLARITY? SDA effect is obliterated if the polarity of both speakers is backwards. A batch of SDA-SRS (1.2, perhaps?) were built with the polarity marked wrong on the binding posts.
2. If the SDA cable--including the cabinet sockets and internal cabinet wiring--doesn't have continuity, there'll be no SDA effect.
Valid, but ONLY for the earliest generation or two of SDA speakers. All the later-generation SDA speakers have the SDA drivers double-teaming the bass. They'll still play bass even with the SDA cable disconnected.Do half the midwoofers stop playing when you disconnect the interconnect that play while connected? -
Ahh. Was just wondering if maybe there was an internal wiring/cap problem regarding the SDA "circuitry". How do you troubleshoot that then?Valid, but ONLY for the earliest generation or two of SDA speakers. All the later-generation SDA speakers have the SDA drivers double-teaming the bass. They'll still play bass even with the SDA cable disconnected.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
You'll have to play around with speaker position and your seating distance. What you've got right now does not seem ideal to me. I have mine 6 feet apart and sit 9 feet back, which is ideal in my room. However, the manual suggests an equilateral triangle.The phono is similar to the CD player, not a major difference.
Sony CDP's are notoriously bright, especially those mega changers and there are plenty of bright phono rigs. Other possible causes are your room, cables, pre-amp, etc.I had them 10" off the wall and since moved them to 3",Noticed a bass increase.
5 to 6 inches is usually ideal. 3 inches is way too close, the bass will be a boomy mess that close.I swapped cords from my 3.1's and still the same. It's hard to tell if there is change when I'm behind them to unplug the interconnect.
You won't be able to tell what's what standing behind them.Political Correctness'.........defined
There's a trouble-shooting guide that's already been linked-to in an earlier post.Ahh. Was just wondering if maybe there was an internal wiring/cap problem regarding the SDA "circuitry". How do you troubleshoot that then?
The end result is that if the SDA wiring and drivers are working, the soundstage will be hugely wide, and if it isn't, the soundstage will be "ordinary" to "narrow".
Perhaps true. I can tell that the sound changes when I unplug the SDA interconnect cable by crouching to the side of my 1Bs and reaching around to the back to unplug the SDA interconnect cable. It's not a huge difference listening close-up and to the side like that...but it is noticeable.You won't be able to tell what's what standing behind them.
There's a huge difference in soundstage--but not in tone or frequency-response--when seated in the normal listening position and having someone else plug/unplug the SDA interconnect. -
Not sure about the 1.2 sets but on the 2Bs all the drivers look exactly the same. Wackyer things have happened as in reversed polarity wiring and someone just putting in the same drivers 6503/stereo and 6511/dimensensional which again look exactly the same. Your seating is just about the same as mine as I have a 7' spred on the speakers and 9' feet dead center listening spot which is almost an equilatateral triangle. Do the disconnect of the i/c test and see if you just get stereo, play a while then reconnect. It is that different even I noticed it and my ears are not made of any precious metals. Oh, bright should not be the outstanding feature, if anything bass heavy would be my comment and not a complaint. D/L the handbook if you have not already done so it will help explain all the theory, set-up,testing and some diagrams to to show the interaural effect. Mine sound wise sounds like it's coming from everywhere so I rarely use my H/T Klipsch smalls any more.
http://vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdf2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Polarity may be an issue. The original SRSs had the polarity reversed at the factory. I just rebuilt a pair of 1.2s, and the factory wiring was correct, but someone had switched the red and black plastic nuts on the binding post cups. You may want to pull the binding Post cups, and check the internal wire connections vs the color coded, plastic binding post nuts.Home Theater/2 Channel:
When i got my SRS I had this same issue. It ended up being some oxidation in the interconnect socket at one terminal cup.If con is the opposite of pro, is Congress the opposite of Progress?!
Monitor 5Jr, Monitor 5, RTA12, RTA 15TL, SDA 2A, 1c, SRS 2, 1.2TL, CRS, Atrium. -
I will check posts for reverse plastic knobs, I will contact the old owner to see if any drivers have been replaced but I think he said they were all original. Check for corrosion(I have 2 cords though) and get the wife to pull the cord out
Mcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Basic Wiring
SDA-1.2TL
Disconnect speaker wires at the amplifier.
Disconnect the IC cable.
Connect a 1.5 volt flashlight battery momentarily to the speaker wires of left speaker observing polarity. Watch to see if all the MWs move outward when the battery is connected. If thy do the speakers are wired correctly. Check the right speaker the same way.- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
When your doing your testing, search the SDA threads for music that offers the best SDA effect, should make testing a little easier.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
There is a list in the last page of the bookletMcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Basic Wiring
SDA-1.2TL
It might sound silly, but you got a "Mono/Stereo" switch on your preamp that needs to be checked?
EXCELLENT suggestion.George Grand wrote: »It might sound silly, but you got a "Mono/Stereo" switch on your preamp that needs to be checked? -
There is a mono/stereo switch on the amp, it is on StereoMcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Basic Wiring
SDA-1.2TL
Which "amp" has the switch on it? It needs to be the one on the preamp that is also in the stereo position.
George Grand wrote: »Which "amp" has the switch on it? It needs to be the one on the preamp that is also in the stereo position.
Everything is in stereo mode.Mcintosh MC2300
Mcintosh 2105
Integra Pre amp 9.8
Basic Wiring
SDA-1.2TL
I hate to say it but it is very noticeable when I plug and unplug the cable.
The mid range, which is where most of the music is anyway, on the SDA drivers quits.
So it's just like I unhooked the drivers.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
could it be a phasing issue inside the cabinets? Another idea would be to check the speaker connections for proper phasing...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Hi,I'm experiencing the same problem and was wondering if you ever resolved the problem? Ive tried all the above tests except the battery one [gonna try it later] In my situation I'm wondering if my room may be too small.Spaced at apx. 4.5' I've got about 2.5' to the sidewalls.Should i get a definitely noticeable effect when seated about 6' back? [ I have the sda1's with the horizontally mounted tweeters ]
That's not a lot of separation, and the close proximity to the side walls may cause early reflections, which would play havoc with any speaker, not just SDAs.
You can try disconnecting the outer Dimensional Tweeters. These were eliminated on later models, and may improve the overall sound.
If your pre-amp or integrated has a balance control, you can check whether the SDA circuit is working properly very easily.Home Theater/2 Channel:
If 1.2's, double-check your red posts are on the left regardless of what the plate sticker indicates. Dunno if others came from the factory crossed up.
http://forum.polkaudio.com/discussion/comment/1818501#Comment_1818501Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
