Water heater question....
steveinaz
My bunkhouse has an electric water heater, I think about a 20 gallon or so. If I use this heater rarely, should I leave it empty---and then refill and turn on when visitors will be in the bunkhouse? Currently I leave it full, but turned off, and the water of course gets to smelling bad.
Post edited by steveinaz on
Not a bad Idea to drain it. The anode rod is being eaten away needlessly.Home Theater/2 Channel:
dhsspeakerservice.com/ -
If you can afford it you'd probably be served better by an "on demand" electrical heating unit with a dedicated circuit for it. Heats water as needed, no real tank--I believe. They were ubiquitous in China when I was there.
Sure the electrical costs are high. But only when used so if you use it sparingly, that shouldn't be a problem.
It only gets used about 1 week a year, so no big deal.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Definitely drain it, or else you risk getting Legionella. Not to mention that water that stagnant for that long is absolutely disgusting, there's so many bad things about it that it's not even worth making a list.
http://en.wikipedia.org/wiki/LegionellaToo many good quotes to list..waiting for some fresh ammo.
I concur with Cnh,
I am a maintenance tech for for a property investment/management company and deal with things like this on a daily basis(would rather do something else lol
But just drain. Flush tank for about 5-10 minutes.
I work on people's water heater's a lot especially snowbirds.
And have to flush 3/5 heaters as well as need to change the elements
Due to them getting so bad that it is almost impossible to pull them out when changing them.
Hope this helps.Polk Lsi9
Polk LsiC
Polk Fxi3
Pioneer SC-1222
Parasound 1200 II w/ Kimber Kable HERO + 4TC
SVS PB12-NSD (Bash)
PS4
Sharp Aquos 55"
"If your BOLD enough to try it,
your BOLD enough to make it happen" -
Cool, appreciate the help fellers. I'll drain that pup.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
