Looking for a center channel to go w/ my Lsi9's
pumpkinman
pumpkinman Posts: 10,546
edited July 2014 in Speakers
Hi all,
To start off with I know less than nothing about home theater. I have a pair of Lsi9's that I want to use as fronts. Looking for a center channel and a set of rear speakers. But I can buy the center 1st and the rears later if need be. I see another Polkie has an LisC for $200 but I'm looking to spend as little as possible to start with. I have a late 90's JVC AVR. I'm looking for something of a home theater experience but it doesn't have to be perfect. Hell I watch movies now with nothing more than the speakers in the TV (which suck I might add LOL)
I found this on my local Craigslist. My question to you boys and girls is a decent match for the Lsi9's or should I steer clear
http://allentown.craigslist.org/ele/4491619713.html
Thanks all...........P-man
Because I am The Pumpkinking
  • chumlie
    chumlie Posts: 8,658
    edited June 2014
    Another thumbs up on the LSiC. If its still there.
  • pyrocyborg
    pyrocyborg Posts: 524
    edited June 2014
    +1 for LSiC.
    Another thing: is your JVC avr 4 ohm capable or do you have a spare amplifier for them?
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
  • pumpkinman
    edited June 2014
    pyrocyborg wrote: »
    +1 for LSiC.
    I'll have to look into that. Thanks
  • pumpkinman
    edited June 2014
    pyrocyborg wrote: »
    +1 for LSiC.
    Looks like a big ''no'' on the 4 ohm. So ends my journey. I'll just run a pair of fronts and watch movies that way
  • rooftop59
    rooftop59 Posts: 8,120
    edited June 2014
    pumpkinman wrote: »
    I think that your LSi9s with decent power would might nice 2 channel HT. Dynamic, good bass response, big soundstage, should be very enjoyable overall.
    Game Room 5.1.4:
    Bedroom 2.1
  • Monster Jam
    Monster Jam Posts: 919
    edited July 2014
    Consider also another pair of LSi9s or a pair of LSi7s.
    Do you hear that buzzing noise? :confused:
  • psuie23
    I recently came into possession of a pair of LSI9's. I like them a lot so far! I have a small polk sub which I am going to replace with a Velodyne 12" which I have in my basement. For the center channel I currently have an old polk with two 6" woofers. I think it is a CSi400. I'm thinking that is not terribly well matched with the fronts. Would something like the LSiC be better matched? I can't seem to find too many of them available.
    For my rears I'm using old FX500 I believe. I wonder if this is close enough for rears.
  • ken brydson
    ken brydson Posts: 9,107
    edited November 2015
    psuie23 wrote: »
    The LSiC is the perfect match for your 9's. Keep an eye out for one. It is most important to have your front 3 be of the same series. You're 500's are probably OK for HT. Might keep an eye out for a pair of LSi7's for a full matched set. Good luck.
  • psuie23
    Ken - Thank you for the information. Is the LSiC the only center channel from that speaker series? Aside from the issue of availability, I wish it came in some different finishes.
  • psuie23
    Ken - One down side of using the LSI in the back is that based on my room I need to use the speakers on the side walls (either side of the couch which is against the back wall). I wonder if that would be problematic for bookshelves. Would it be not dispersed enough for home theater but too directional for music?
  • ken brydson
    Bipole/dipoles are better on the sides IMO. Keep an eye out for some LSiFx's, keeping in mind they are harder to find than a LSiC. In the meantime your current 500's will be fine. Unfortunately the LSiC is the only timbre matched center for that line. If it's just the finish that bothers you I suppose you could re veneer it. Good luck in your quest...
