NAD Remotes
Jstas
Jstas Posts: 14,998
edited June 2014 in Electronics
OK, I have a C370 integrated and it had a remote when I got it.
It currently doesn't have a remote because I'm pretty sure my ex threw it out at some point 'cause she's a ****.
I know I can get a universal to work with it but I'd rather have the original style remote if at all possible. Anybody know where I could find one?
Aside from eBay if possible.
Expert Moron Extraordinaire
Post edited by Jstas on
    edited June 2014
    I have a similar problem. My C325 remote no longer works.
    This site has some duplicates for the C370. One is VERY PRICEY. The other looks nothing like the original but is much cheaper. I think there is another site as well, I'll see if I can dig that up; I bought a Denon remote from them that worked fine!
    http://remotes.com/remotes/servlet/rs?a=gmi&smodel=C370&brand_pn=NAD_C370&mode=large&uuid=14032924568890
    cnh
  • gimpod
    gimpod Posts: 1,793
    edited June 2014
    Jstas wrote: »
    That's sig material & I'm stealing it 'cause I'm a **** too. :wink::redface:
  • voltz
    voltz Posts: 5,384
    edited June 2014
    That is a classic!
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited June 2014
    My nads are too old, they didnt come with remotes!
    Sorry just couldn't stop myself.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
