NAD Remotes
Jstas
OK, I have a C370 integrated and it had a remote when I got it.
It currently doesn't have a remote because I'm pretty sure my ex threw it out at some point 'cause she's a ****.
I know I can get a universal to work with it but I'd rather have the original style remote if at all possible. Anybody know where I could find one?
Aside from eBay if possible.
Expert Moron Extraordinaire
Post edited by Jstas on
I have a similar problem. My C325 remote no longer works.
This site has some duplicates for the C370. One is VERY PRICEY. The other looks nothing like the original but is much cheaper. I think there is another site as well, I'll see if I can dig that up; I bought a Denon remote from them that worked fine!
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=C370&brand_pn=NAD_C370&mode=large&uuid=14032924568890
That's sig material & I'm stealing it 'cause I'm a **** too.
:redface: “The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
That is a classic!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
My nads are too old, they didnt come with remotes!
Sorry just couldn't stop myself.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
