Do I have bad taste in sound?
Nightfall
Simple enough - "Pure Direct", bypassing an AVR's sound altering electronics, is touted by many to sound superior. I think that when I engage Pure Direct mode that the sound becomes lifeless, dull, passive, ...worse. Does this mean that I have "bad" taste in sound?
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk
Post edited by Nightfall on
I don't see an Emo in your sig, so I would say you're good.
I feel the same way. My AVR has direct and pure direct. "Direct" shuts down some, but not all features. I hate music in pure direct, and pure direct shuts down the signal to my sub. I always use direct for CDs, it just sounds much better to me.
LOL! Yep, just about spit my coffee out all over the screen on that one John!nooshinjohn wrote: »I don't see an Emo in your sig, so I would say you're good.
No, it just means whatever source your feeding the receiver isn't as good SQ wise than the receiver itself.HT SYSTEM-
lsi 9's -
If you're referring to that Yammaha 667, I can believe it would sound worse in DIRECT mode. Blanket beliefs about EQ-ing applied to all kinds of equipment leave no room for your ears to be the final word.
I'm guilty myself. I have some equalization on my NAD below because I just could not get a full enough sound with none no matter what I tried (sources, cables, different pres, etc. the speakers [B.A. A200s] just needed a PUSH).
Nothing is written in stone. You have to do what your ears tell you or else you're just lying to yourself in order not to violate an audio truism.
If you're use to equalized sound, pure direct or bypasing tone controls can take a bit of getting used to. At first it will sound veiled; but with time, you will notice far better tonal linearity across the spectrum. In laymens terms, no specific frequencies will sound like they are pushed ahead of other frequencies. This results in an overall smoother sound, especially at higher volumes.
Give it time. Years and years ago, to "wean" myself off the treble knob, I actually spent a week with the treble cut in the lowest setting; so when I went back to the 0db position, it acually sounded quite good. Never looked back.
Once you get used to the increased linearity of running tone defeated, you wonder why you ever used it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I once dated an ugly chick, just to make average chicks look better. At least, that's what I tell myself! -
So long as YOU like it no other opinion matters. Sit back and enjoy.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Village Idiot of Club Polk -
He's from Texas, cut old Skip a break. lolHT SYSTEM-
lsi 9's -
I can't taste what you taste, so do whatever sounds best to you. Everybody has something that sounds better to them.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
lsi 9's -
I never thought I'd be one to subscribe to this, but it's happening. slowly. I found myself the other night feeling put off by uncomfortable highs at volume, brought on with even just a minor bump in treble. I agree with the "linearity" bit, and smoothness at higher volumes. and also agreed, it does take time. if you asked me this three months ago, I'd have said no way. for me it also depends on the system and space, I'm finding. for instance, I'm probably not ready to go "direct" in my vehiclesIf you're use to equalized sound, pure direct or bypasing tone controls can take a bit of getting used to. At first it will sound veiled; but with time, you will notice far better tonal linearity across the spectrum. In laymens terms, no specific frequencies will sound like they are pushed ahead of other frequencies. This results in an overall smoother sound, especially at higher volumes.
Give it time. Years and years ago, to "wean" myself off the treble knob, I actually spent a week with the treble cut in the lowest setting; so when I went back to the 0db position, it actually sounded quite good. Never looked back.
yes, taste does change - I've noticed it even in just 6 months of listening more closely than I used to.My point? Your 'taste' changes over time. You figure out what sounds good and what doesn't, and where your happy medium is. You've listened to enough speakers that you probably know what your tonal preference is. Now you need to get out and see what a true stereo system can do with quality components throughout the chain. I'm not trashing your system - I merely think your expectations might be higher than what it can provide, causing you to second guess yourself.I disabled signatures. -
It only matters what sounds good to you!Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c -
The purpose of Pure Direct in the realm of AVRs is not for digitally connected source components - it is intended for preserving the analog 'chain' thru the AVR for analog connected devices(such as turntables, or analog out from CD/SACD or external DACs).
If that isn't important, move on.
I am going to say it depends also on your room acoustics. If they are bad, the dsp helps a lot!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
LOL, you just ruined my afternoon tea. It's on my keyboard nowI once dated an ugly chick, just to make average chicks look better. At least, that's what I tell myself!Home Theater/2 Channel:
dhsspeakerservice.com/ -
I use Pure Direct For 2 channel only, and my 2As dig deep enough and are smooth as silk. Anything HT related gets the full equalized treatment. As others have said, could be room related, or you're more accustomed to the equalized sound. My Pioneer has Direct also, which leaves the subs in but nothing else.Simple enough - "Pure Direct", bypassing an AVR's sound altering electronics, is touted by many to sound superior. I think that when I engage Pure Direct mode that the sound becomes lifeless, dull, passive, ...worse. Does this mean that I have "bad" taste in sound?Home Theater/2 Channel:
I also dont like the "Direct" setting on my Integra, choosing instead to use "Stereo" which keeps the Audyssey processing and crossovers and adds in my sub.
I even wear skinny jeans and run around knocking over Projectors and my center channel that I put on a upside down laundry basket thats sitting on the floor..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
NightFall I also have the pure direct feature w/ my Yamaha RX-V665. To say I was grossly disappointed would be a understatement. The avr does a lot but power was not one of those features that impressed me. The Pure Direct front 2 for stereo also a very lack luster performer. Not even knowing at the time I was lucky to have pre/outs and got the Adcom to make up for most of the inadequacies. I moved away from H/T to go w/ 2 chl. for the most part.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
That may be true for some AVRs, but not my Pioneer. According to the manual, when set to pure direct, all sources, whether digital or analog, are passed directly from the inputs to the gain stage and out to the pre-amp out jacks, or internal amp. The digital sources pass through the DACs first obviously, but that's it. No other processing occurs.Erik Tracy wrote: »The purpose of Pure Direct in the realm of AVRs is not for digitally connected source components - it is intended for preserving the analog 'chain' thru the AVR for analog connected devices(such as turntables, or analog out from CD/SACD or external DACs).
If that isn't important, move on.Home Theater/2 Channel:
Same with Yamaha.westmassguy wrote: »That may be true for some AVRs, but not my Pioneer. According to the manual, when set to pure direct, all sources, whether digital or analog, are passed directly from the inputs to the gain stage and out to the pre-amp out jacks, or internal amp. The digital sources pass through the DACs first obviously, but that's it. No other processing occurs.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
EndersShadow wrote: »I also dont like the "Direct" setting on my Integra, choosing instead to use "Stereo" which keeps the Audyssey processing and crossovers and adds in my sub.
On my old Denon, it was Pure Direct all the time. On my new Marantz, I listen to Audyssey XT32 and Sub EQ 100% of the time and it sounds great. Everybody prefers something different but I can't go back to Pure Direct and I have a well treated room._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
