Do I have bad taste in sound?
Nightfall
Nightfall Posts: 10,084
edited June 2014 in Electronics
Simple enough - "Pure Direct", bypassing an AVR's sound altering electronics, is touted by many to sound superior. I think that when I engage Pure Direct mode that the sound becomes lifeless, dull, passive, ...worse. Does this mean that I have "bad" taste in sound?
afterburnt wrote: »
Village Idiot of Club Polk
Post edited by Nightfall on
    nooshinjohn Posts: 25,898
    edited June 2014
    I don't see an Emo in your sig, so I would say you're good. :lol::lol::lol:
  • Hermitism
    Hermitism Posts: 4,325
    edited June 2014
    I feel the same way. My AVR has direct and pure direct. "Direct" shuts down some, but not all features. I hate music in pure direct, and pure direct shuts down the signal to my sub. I always use direct for CDs, it just sounds much better to me.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited June 2014
    LOL! Yep, just about spit my coffee out all over the screen on that one John!
    tonyb Posts: 33,069
    edited June 2014
    Nightfall wrote: »
    No, it just means whatever source your feeding the receiver isn't as good SQ wise than the receiver itself.
    edited June 2014
    If you're referring to that Yammaha 667, I can believe it would sound worse in DIRECT mode. Blanket beliefs about EQ-ing applied to all kinds of equipment leave no room for your ears to be the final word.
    I'm guilty myself. I have some equalization on my NAD below because I just could not get a full enough sound with none no matter what I tried (sources, cables, different pres, etc. the speakers [B.A. A200s] just needed a PUSH).
    Nothing is written in stone. You have to do what your ears tell you or else you're just lying to yourself in order not to violate an audio truism.
    cnh
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2014
    If you're use to equalized sound, pure direct or bypasing tone controls can take a bit of getting used to. At first it will sound veiled; but with time, you will notice far better tonal linearity across the spectrum. In laymens terms, no specific frequencies will sound like they are pushed ahead of other frequencies. This results in an overall smoother sound, especially at higher volumes.
    Give it time. Years and years ago, to "wean" myself off the treble knob, I actually spent a week with the treble cut in the lowest setting; so when I went back to the 0db position, it acually sounded quite good. Never looked back.
    Once you get used to the increased linearity of running tone defeated, you wonder why you ever used it.
  • Hermitism
    edited June 2014
    steveinaz wrote: »
    I once dated an ugly chick, just to make average chicks look better. At least, that's what I tell myself!
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2014
    So long as YOU like it no other opinion matters. Sit back and enjoy.
  • Nightfall
    edited June 2014
    DSkip wrote: »
    Mystery, how many high end rigs have you heard in a well setup room?
    Wrong person. :)
    afterburnt wrote: »
    tonyb Posts: 33,069
    edited June 2014
    He's from Texas, cut old Skip a break. lol
  • zane77
    zane77 Posts: 1,696
    edited June 2014
    I can't taste what you taste, so do whatever sounds best to you. Everybody has something that sounds better to them.
    Two Channel
    tonyb Posts: 33,069
    edited June 2014
    zane77 wrote: »
    Ya know....I'm just gonna leave that one alone. LOL
  • Zeros
    Zeros Posts: 940
    edited June 2014
    tonyb wrote: »
    Do you see what I see....
    msg Posts: 10,452
    edited June 2014
    steveinaz wrote: »
    Give it time. Years and years ago, to "wean" myself off the treble knob, I actually spent a week with the treble cut in the lowest setting; so when I went back to the 0db position, it actually sounded quite good. Never looked back.
    I never thought I'd be one to subscribe to this, but it's happening. slowly. I found myself the other night feeling put off by uncomfortable highs at volume, brought on with even just a minor bump in treble. I agree with the "linearity" bit, and smoothness at higher volumes. and also agreed, it does take time. if you asked me this three months ago, I'd have said no way. for me it also depends on the system and space, I'm finding. for instance, I'm probably not ready to go "direct" in my vehicles :)
    DSkip wrote: »
    My point? Your 'taste' changes over time. You figure out what sounds good and what doesn't, and where your happy medium is. You've listened to enough speakers that you probably know what your tonal preference is. Now you need to get out and see what a true stereo system can do with quality components throughout the chain. I'm not trashing your system - I merely think your expectations might be higher than what it can provide, causing you to second guess yourself.
    yes, taste does change - I've noticed it even in just 6 months of listening more closely than I used to.
  • Sea
    Sea Posts: 317
    edited June 2014
    It only matters what sounds good to you!
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited June 2014
    The purpose of Pure Direct in the realm of AVRs is not for digitally connected source components - it is intended for preserving the analog 'chain' thru the AVR for analog connected devices(such as turntables, or analog out from CD/SACD or external DACs).
    If that isn't important, move on.
  • erniejade
    erniejade Posts: 6,321
    edited June 2014
    I am going to say it depends also on your room acoustics. If they are bad, the dsp helps a lot!
  • westmassguy
    westmassguy Posts: 6,850
    edited June 2014
    Hermitism wrote: »
    LOL, you just ruined my afternoon tea. It's on my keyboard now
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • westmassguy
    edited June 2014
    Nightfall wrote: »
    I use Pure Direct For 2 channel only, and my 2As dig deep enough and are smooth as silk. Anything HT related gets the full equalized treatment. As others have said, could be room related, or you're more accustomed to the equalized sound. My Pioneer has Direct also, which leaves the subs in but nothing else.
    EndersShadow Posts: 17,698
    edited June 2014
    I also dont like the "Direct" setting on my Integra, choosing instead to use "Stereo" which keeps the Audyssey processing and crossovers and adds in my sub.
    I even wear skinny jeans and run around knocking over Projectors and my center channel that I put on a upside down laundry basket thats sitting on the floor...
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited June 2014
    NightFall I also have the pure direct feature w/ my Yamaha RX-V665. To say I was grossly disappointed would be a understatement. The avr does a lot but power was not one of those features that impressed me. The Pure Direct front 2 for stereo also a very lack luster performer. Not even knowing at the time I was lucky to have pre/outs and got the Adcom to make up for most of the inadequacies. I moved away from H/T to go w/ 2 chl. for the most part.
  • westmassguy
    edited June 2014
    Erik Tracy wrote: »
    That may be true for some AVRs, but not my Pioneer. According to the manual, when set to pure direct, all sources, whether digital or analog, are passed directly from the inputs to the gain stage and out to the pre-amp out jacks, or internal amp. The digital sources pass through the DACs first obviously, but that's it. No other processing occurs.
  • Nightfall
    edited June 2014
    Same with Yamaha.
    afterburnt wrote: »
  • Thorton
    Thorton Posts: 1,324
    edited June 2014
    On my old Denon, it was Pure Direct all the time. On my new Marantz, I listen to Audyssey XT32 and Sub EQ 100% of the time and it sounds great. Everybody prefers something different but I can't go back to Pure Direct and I have a well treated room.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
