Anyone using Crown amps?
I hooked up my friends crown xls amp to my rta 11 and it sounded horrible compared to my nad amp and even my yamaha receiver . They lacked a lot of bass . But everyone has different tastesYamaha V1800 receiver along with a NAD 2600a and 2700a .
Sda 1c - my new favorite speakers
Rta 8,11tl,15tl
Monitor 10 and 12
Marty sub 18" still in the works
Klipsch sw12-2
Hobbies turn into addictions . -
Let me throw out this scenario
I am a believer of having of having multiple systems as an audiophile as some music sounds better/different on some systems than others. I just have these moods so I switch systems. I have a garage/desktop system that I can stream music, play poorly recorded music and not flinch or pick it apart.
I have another rig that plays jazz, blues, and classical very well. My Dynaudio system lays right in the middle but excels with vocals.
I have played with pro-gear but it has it harsh peaks or thin in the mids.
Maybe we can can blame some poorly recorded music or music in general on what type gear it was recorded on. Maybe the system we have at home needs to match the most of the crap that is recorded.
All music can only sound its best when recorded fairly well or as well it's recorded ....You can spray perfume on body odor but it's still gonna stink.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
The DSP function is great and they definitely aren't bright. But, I'm still glad I'm only using them on high efficiency drivers and only from 450hz and below. With low efficiency drivers, the fans kick on and they are far from quiet...even with upgraded fans. FYI, these amps are A/B, not class D like their other products.Habanero Monk wrote: »Had a chance to play around with the XTi 4002. Well built amp and found nothing harsh, muddied, bright etc about it.
The DSP function kicked ****.
Here's a pic:
The enclosures still aren't finished, hence why they look that way.
Still want to try one or two more test enclosures before saying "I'm done". "He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Here's a pic:
Longhorns...
Here's a pic:
DANNGGG MAN! Those look sexy. Not a chance in hell I could rock those with the glossy black horn, but they look darned fine!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I have the 4002 setup to drive a MBM and LLT sub. Fan setting is turned to low and it doesn't come on even when you are getting blown out of your seat. I don't know if that due to it's being a higher wattage amp and only using for 100Hz on down.
Nice looking setup BTW. -
Cannot disagree w/ any of that. I do know my punk music sounds harsh, brash, and snotty on my Emo.txcoastal1 wrote: »Let me throw out this scenario
All music can only sound its best when recorded fairly well or as well it's recorded ....You can spray perfume on body odor but it's still gonna stink. -
rednedtugent wrote: »Cannot disagree w/ any of that. I do know my punk music sounds harsh, brash, and snotty on my Emo.
Isn't that how punk is supposed to sound?
Three 20 amp circuits. -
Obviously the Emo is the problem here, as punk music is known primarily for smooth vocals, liquid midrange loaded with micro-details and bass that is tight, fast and articulate.
I still have my Crown Powerbase-1, but don't use it very often since the fan noise is a little annoying even in the garage. I hauled it all over town for 10 years while I was a DJ. It's not tight nor very clean, I mean 0.1%THD is not very good these days. But it got dropped, rolled out of the back of a truck, left out all night on a porch, an inverter on a tour boat tried to kill it once, but it still works and like someone posted earlier, hooked up to some crappy custom boxes I built 20 years ago can rip the face off of most anything anyone leaves lying around their garage.
I think that's what they were built for, survival. That and face-melting.
Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Mains: 2x Polk RTA 8TL's
Center: Polk CS245i
Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
Rear Surr: 2x Polk M4a '90
Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
Display: Samsung 55" UNC55-8000 3D LED
Console: Xbox360
DVR: custom MythTV rig w/ 3 tuners OTA
Zone2: 2x Polk M5b '87
