Anyone using Crown amps?
13»
  • Dropthebeat
    Dropthebeat Posts: 154
    edited June 2014
    I hooked up my friends crown xls amp to my rta 11 and it sounded horrible compared to my nad amp and even my yamaha receiver . They lacked a lot of bass . But everyone has different tastes
    Yamaha V1800 receiver along with a NAD 2600a and 2700a .
    Sda 1c - my new favorite speakers
    Rta 8,11tl,15tl
    Monitor 10 and 12
    Marty sub 18" still in the works
    Klipsch sw12-2
    Hobbies turn into addictions .
    txcoastal1 Posts: 13,503
    edited June 2014
    Let me throw out this scenario
    I am a believer of having of having multiple systems as an audiophile as some music sounds better/different on some systems than others. I just have these moods so I switch systems. I have a garage/desktop system that I can stream music, play poorly recorded music and not flinch or pick it apart.
    I have another rig that plays jazz, blues, and classical very well. My Dynaudio system lays right in the middle but excels with vocals.
    I have played with pro-gear but it has it harsh peaks or thin in the mids.
    Maybe we can can blame some poorly recorded music or music in general on what type gear it was recorded on. Maybe the system we have at home needs to match the most of the crap that is recorded.
    All music can only sound its best when recorded fairly well or as well it's recorded ....You can spray perfume on body odor but it's still gonna stink.
  • Face
    Face Posts: 14,340
    edited June 2014
    Had a chance to play around with the XTi 4002. Well built amp and found nothing harsh, muddied, bright etc about it.
    The DSP function kicked ****.
    The DSP function is great and they definitely aren't bright. But, I'm still glad I'm only using them on high efficiency drivers and only from 450hz and below. With low efficiency drivers, the fans kick on and they are far from quiet...even with upgraded fans. FYI, these amps are A/B, not class D like their other products.
    Here's a pic:
    The enclosures still aren't finished, hence why they look that way. :smile: Still want to try one or two more test enclosures before saying "I'm done".
  • Mystery
    Mystery Posts: 2,546
    edited June 2014
    Face wrote: »
    Here's a pic:
    Longhorns... :wink:
    EndersShadow Posts: 17,693
    edited June 2014
    Face wrote: »
    Here's a pic:
    DANNGGG MAN! Those look sexy. Not a chance in hell I could rock those with the glossy black horn, but they look darned fine!
  • Habanero Monk
    Habanero Monk Posts: 715
    edited June 2014
    Face wrote: »
    I have the 4002 setup to drive a MBM and LLT sub. Fan setting is turned to low and it doesn't come on even when you are getting blown out of your seat. I don't know if that due to it's being a higher wattage amp and only using for 100Hz on down.
    Nice looking setup BTW.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited June 2014
    Cannot disagree w/ any of that. I do know my punk music sounds harsh, brash, and snotty on my Emo.
    txcoastal1 wrote: »
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2014
    Isn't that how punk is supposed to sound? :smile:
    nooshinjohn Posts: 25,893
    edited June 2014
    BlueFox wrote: »
    Obviously the Emo is the problem here, as punk music is known primarily for smooth vocals, liquid midrange loaded with micro-details and bass that is tight, fast and articulate.:lol:
  • Zentish
    Zentish Posts: 127
    edited June 2014
    I still have my Crown Powerbase-1, but don't use it very often since the fan noise is a little annoying even in the garage. I hauled it all over town for 10 years while I was a DJ. It's not tight nor very clean, I mean 0.1%THD is not very good these days. But it got dropped, rolled out of the back of a truck, left out all night on a porch, an inverter on a tour boat tried to kill it once, but it still works and like someone posted earlier, hooked up to some crappy custom boxes I built 20 years ago can rip the face off of most anything anyone leaves lying around their garage.
    I think that's what they were built for, survival. That and face-melting.
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
