Paradigm X-30, SVS and SDA 1C's
I-SIG
Anyone think it would be worth it to bypass my SVS's crossover and phasing and filter the lows off my 1C's using the Paradigm X-30? Or should I simply try using the X-30 to filter the 1C's and use the SVS controls? Just htinking about trying somehting different.
Wes
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
How do you have the 1C's hooked up now?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
The AA DLC has two sets of outputs. One runs to the Parasound and the other set runs to the SVS. The 1C's are not crossed over in anyway, besides the internal crossovers.
WesLink: http://polkarmy.com/forums
