Paradigm X-30, SVS and SDA 1C's
I-SIG
I-SIG Posts: 2,243
Anyone think it would be worth it to bypass my SVS's crossover and phasing and filter the lows off my 1C's using the Paradigm X-30? Or should I simply try using the X-30 to filter the 1C's and use the SVS controls? Just htinking about trying somehting different.
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • dorokusai
    dorokusai Posts: 25,638
    edited July 2004
    How do you have the 1C's hooked up now?
  • I-SIG
    I-SIG Posts: 2,243
    edited July 2004
    The AA DLC has two sets of outputs. One runs to the Parasound and the other set runs to the SVS. The 1C's are not crossed over in anyway, besides the internal crossovers.
    Wes
