Could a PSW350 be used as a good mid base module to supplement a hsu vtf3-mk4?
All,
I have my old psw350 boxed up in the basement collecting dust and was wondering if it would be good to be used as a mid-base module. Now I know it is really underpowered, but heck since it is sitting around why not try. my only concern is that I don't
think that there is any way to limit the sub from playing less that 50hz. Your thoughts?
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
Monster HTS 3600
It would require an active crossover network to give you a bandpass signal to use it as a upper range mid bass woofer, but it could be done. The 350 was actually one of Polk's better subwoofers in its day. I still use one in my living room rig with RTi towers.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Why....would you want to use it as a mid bass module ? The HSU isn't enough for you....the RTI 7's ? If not, then re-think your speakers and or sub. Maybe an amp would help bring out more of those 7's too.HT SYSTEM-
lsi 9's -
Tonyb and nbrowser,
I am not sure you can have enough base when it comes to watching movies. I love my vtf3-mk4 it is amazing. Just thinking that a MBM would make the theater room even better.Sharp LC-80uq17u
Monster HTS 3600
Logitech Harmony elite (Remote) -
nbrowser,
Thanks for the advice. I will look into it. I have considered an amp and I should probably consider it more. I appreciate the time that you put into your responses. Thanks!
ChipSharp LC-80uq17u
Monster HTS 3600
nbrowser,
What do you think about this amp? The Parasound HCA-1205A? would 140 w/ch be a huge enough change over my current setup?
Monster HTS 3600
