Could a PSW350 be used as a good mid base module to supplement a hsu vtf3-mk4?
chiptouz
chiptouz Posts: 152
edited June 2014 in Speakers
All,
I have my old psw350 boxed up in the basement collecting dust and was wondering if it would be good to be used as a mid-base module. Now I know it is really underpowered, but heck since it is sitting around why not try. my only concern is that I don't
think that there is any way to limit the sub from playing less that 50hz. Your thoughts?
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited June 2014
    It would require an active crossover network to give you a bandpass signal to use it as a upper range mid bass woofer, but it could be done. The 350 was actually one of Polk's better subwoofers in its day. I still use one in my living room rig with RTi towers.
    edited June 2014
    Why....would you want to use it as a mid bass module ? The HSU isn't enough for you....the RTI 7's ? If not, then re-think your speakers and or sub. Maybe an amp would help bring out more of those 7's too.
  • chiptouz
    chiptouz Posts: 152
    edited June 2014
    Tonyb and nbrowser,
    I am not sure you can have enough base when it comes to watching movies. I love my vtf3-mk4 it is amazing. Just thinking that a MBM would make the theater room even better.
    Sharp LC-80uq17u
    Monster HTS 3600
  • chiptouz
    chiptouz Posts: 152
    edited June 2014
    nbrowser,
    Thanks for the advice. I will look into it. I have considered an amp and I should probably consider it more. I appreciate the time that you put into your responses. Thanks!
    Chip
    Sharp LC-80uq17u
    Monster HTS 3600
  • chiptouz
    chiptouz Posts: 152
    edited June 2014
    nbrowser,
    What do you think about this amp? The Parasound HCA-1205A? would 140 w/ch be a huge enough change over my current setup?
    Chip
    Sharp LC-80uq17u
    Monster HTS 3600
