riding mower advice
    txcoastal1 Posts: 13,519
    edited June 2014
    The Craftsman from yesteryear is no longer. All they do is rebadge and OEM other manufacturers. I had a **** of a time getting parts for a Craftsman riding mower last year as they change manufacturers every couple years.
    What I have been doing is shopping the big box stores and then google the local authorized repair dealer in the area and buy direct from them. They register the unit for you and know the complete history providing better service and recommendations. Has saved me a lot of headache with warranty and repairs on my heavy equipment plus helps keep the little guy in business.
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited June 2014
    John Deer LT160 from JD dealer on its 12th trouble free season here.
  • mlong
    mlong Posts: 134
    edited June 2014
    I have a Craftsman that I bought when I returned to Maryland. It used to take me 2 1/2 hours to push mow my 1/3 acre so the first thing I did upon returning was buy a tractor. It's certainly not the BEST tractor, but it was only around 900and I've had it for 11 years with no issues.
    [HOME THEATRE]
    Samsung LED HDTV - Pioneer VSX-1014TX (AVR) - Parasound HCA-1200 II - Philips DVP642 (DVD)
    Polk Monitor 10B (Side Surround) - Bang & Olufsen P45 (Rear Surround) - Polk CSi30 (Center Channel)
    SVS PB12-ISD/2 (Sub)
    billbillw Posts: 7,800
    edited June 2014
    mlong wrote: »
    Exactly...who needs "the best" tractor or a zero turn just to cut their yard? Just about any reasonably well built riding mower will cut a 1-2 acre yard every week for 10+ years with typical maintenance of oil changes, lube, belts and blade replacement.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited June 2014
    I just can't imagine how it could take 6 hours unless you have a 20" "manual push" mower.
    As you know the best time to buy what ever it is, is in late September.
    mhardy6647 Posts: 35,241
    edited June 2014
    bought mine used before we moved up here -- from our pastor :-) Seemed like a reasonable risk...
    13081422643_2a286fd24e_b.jpgDSC_6625_z by mhardy6647, on Flickr
    Not exactly "pro-quality" but fit for purpose, with a 46" cutting deck. Makes cuttin' the weeds at the new place a pretty enjoyable task (well, at least so far!)...
  • Jstas
    Jstas Posts: 14,996
    edited June 2014
    PFFT!
    Y'all are amateurs.
    Expert Moron Extraordinaire
    edited June 2014
    The white walls are just too hip!
    edited June 2014
    Jstas wrote: »
    PFFT!
    Y'all are amateurs.
    Not including the custom paint, whitewalls, and red wheels, that looks an awful lot like my late 90's Craftsman EZ3. Mine has a hydro and a double bagger on the back though. I'd rather have the non-hydro trans though. I suspect the trans is going to be what puts my tractor to the grave eventually.
  • read-alot
    read-alot Posts: 812
    edited June 2014
    I bought a 42" Deere at a Deere dealer 6 years ago. No plastic idler pulleys, no parts have worn out. Cuts an acre in an hour....easy peasy, I love it.
    This
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • steveinaz
    steveinaz Posts: 19,546
    edited June 2014
    Do you have an ATV? If so, a swisher finish cut tow behind would be good.
