Blue Jeans
So...when I first posted about new set up I noticed a hum and vibration coming from the motor of the TT...you could feel it in the base...After 3 mins on a search I found the solution and it worked like a charm...she is dead quiet now...4 5/32 rubber washers and 2 #6 brass washers...stack 2 rubber and one brass on top under the 2 screws that hold the motor flanges...there is rubber under but not on top...this completely isolates the motor...
I called it raw when I first posted, that is completely gone...it sounds great...
also running a Herbies audio mat with the original metal platter...
Did they advertize some assembly required....glad things are clean on that end but does this shim set up change motor alignment to any degree. Be curious on any impressions you have on the new blue jean IC. -
Yeah, just keeping it level u will be ok... Its a known flaw i guess....Did not know about it before but I guess some vibrate and some don't...i have no idea how they all aren't...
so far so good on the blue jeans IC's...but I have a lot of things "burning or settling " in, whichever you prefer...speaker crossovers, stylus, and IC's....So it will be a while before i can really give a final thumbs up or down...
with all that said it sounds much better than my old table...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
Glad to here things are improved. I think you've changed more in your system than even I have lately... hard to keep all sorted on the improved SQ front. I got some cables from Tonyb on forum for IC connection and need to evaluate them. Unfortunately it will require a lot of gear movement to plug and play
went a step further....
Project Tube Box S on its way...
got a great deal on a lightly used on flea-bayMarantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
Sounds good I almost bought one, but ended up with a Graham Slee Gram amp 2 SE. so far its made a nice difference.
BTW it should be on its way today
I picked up some Heavy tape on my way home
thanks man...
looking forward to it.....Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
So the best set up is for this TT is..... Herbies mat, speed box S, tube box S, Blue Jeans cables....
sick...!Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
now - how about a pro-ject "Ground it deluxe" ?
http://www.musicdirect.com/p-7625-pro-ject-ground-it-deluxe-platform.aspx
J/kidding
ugh....how about my wife killing me...!
ha...
u get my PM...?Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
finally seen your pm, sent one back.
let me know how you like your Tube Box S, I almost bought one but someone talked me into a Graham Slee and I been really happy with.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
So how are things going with those interconnects?HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
