Douglas Custom Cables Review
marvda1
marvda1 Posts: 4,963
edited May 2014 in Speakers
had a great time this weekend doug, this one's for you. sorry it took so long to get in the lineup.
http://www.stereomojo.com/SwisscablesCablesReview.htm/Douglas%20Connection%20Cables%20Review/DouglasConnectionCablesReview.htm
Puritan PSM156
Post edited by marvda1 on
  • voltz
    voltz Posts: 5,384
    edited May 2014
    Nice review Marvin! really like your warning message about non-plated copper banana's
    Hope you feeling alright after that weekend :)
  • Geoff4rfc
    Geoff4rfc Posts: 2,961
    edited May 2014
    Glad you're enjoying your cable from Doug. Nothing but great positives from a vendor like that. I too have enjoyed my purchases from Doug.
  • amb426amb1
    amb426amb1 Posts: 148
    edited May 2014
    Thank you very much for the informative break down on these entry level products from Doug.
  • Geoff4rfc
    edited May 2014
    amb426amb1 wrote: »
    Why do you call them entry level?
    RCA brand is what I'd call "entry level" from the likes of Lowes and Home Depot, these cables are mile stones above that.
    I'm guessing you probably spend thousands on cables and call that high end?
    F1nut Posts: 52,008
    edited May 2014
    Those would be consumer level, like a $70.00 CDP from Best Buy.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2014
    Geoff4rfc wrote: »
    It's all relative, compared to the other stuff he sells these are his entry level offering.
  • amb426amb1
    edited May 2014
    I'm using the likes of wall-mart stuff and have been spending time looking at higher end alternatives. These are very entry level as stated in the review. I'm at the cheep **** level after spending time on the Douglas connection site.
    edited May 2014
    amb426amb1 wrote: »
    I'm using the likes of wall-mart stuff and have been spending time looking at higher end alternatives. These are very entry level as stated in the review. I'm at the cheep **** level after spending time on the Douglas connection site.[/QUOTE
    You don't have to go from Wal-mart stuff to high end, there's a lot of cable real estate in between.
  • voltz
    voltz Posts: 5,384
    edited May 2014
    I use to think I was the king of speaker cable making LOL :)
    til I came here and read otherwise, & learn the best lesson ever from you all here, that you have to take a chance and try better cables to know if there is a difference, so I 1st got some AQ type 4 no frills from AA for about $100, then some Rocket 33's.
    Now I want to try some Douglas connections alpha's... then I keep what I like the best and give the others to my brother :)
    edited May 2014
    Did you notice any improvement along the way ? Better....worse ...none ? What did your ears tell ya ?
  • amb426amb1
    edited May 2014
    I'll end up buying raw cable and pick some ends for speaker and IC's to make my transition into better sounding cables. Love the DIY projects and helps me take baby steps with the wallet on this section of upgrades.
  • voltz
    voltz Posts: 5,384
    edited May 2014
    The SQ got better each time, as I started noticing a little better sound I change out the IC's also, then when I went to a pre-amp + Amp everything got really better, cause I think (not sure) that everything was starting to burned in (cables & all) and I was using better sources (45rpm vinyl & SACD)
    Thats why I looking at maybe another upgrade. Just can't stop it once the ear's want more. (does it ever stop). maybe a P3 power plant ect... I'm already adding some isolation feet's.
  • Geoff4rfc
    edited May 2014
    amb426amb1 wrote: »
    Sorry man, my reply looked a tad bit forward.
