5JR+ and Pangea speaker stands
This may or may not be a stupid question, but here goes....
Just got and assembled the Pangea Ls200 28" stands, and I am curious if anyone ever drills a hole in the speaker base and maybe drops a screw through to the bottom of the speaker cab. I KNOW I KNOW it seems like sacrilege to do that to the speaker, but man, I know I am going to have a hard time trusting such a small plate for the speaker to sit on....
I am probably over thinking this?
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2
Keces DA-131 mk.II
Use some blue tack between the stands and bottom of the speakers. It makes a more secure connection.
My opinion, those stands are too high. Which ones did you get ? Post a link bro.HT SYSTEM-
lsi 9's -
Blue tack or Velcro, no holes...
Cut a propper size foot plate ( wood or whatever) bolt that to the stand and "place " the speakers on the "new plate" or just but the propper size stands.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I was going to suggest that...^^^, but depending on the stand it could make it top heavy and prone to tilting over. That's why I asked which stand he bought.HT SYSTEM-
lsi 9's -
These here Tony.
http://www.amazon.com/gp/product/B00GLX7S00/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
That puts the tweets just at ear height when I am sitting at my desk. And I was thinking of filling the tube, though not sure with what yet. I find is odd, though, that there is a fill hole at both ends of the tube, and no type of stopper provided.
I have rebuilt crossovers, but the stupid stands just befuddle me.
and thanks everyone. I really didn't want to screw through my fresh veneer....but I wasn't sure if it was considered any different than drilling in spikes.Polk Lsi9
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Aren't those "fill holes" for running the speaker wire through?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Haha, one of the Amazon reviews talks about just that.The biggest disappointment for me is the inability to fill either of the columns with sand. The description of the stand describes the option to fill the columns with sand, but honestly, the only way I could envision adding sand to the columns would be with an eye dropper or a tiny spoon, as the only opening is very, very small. 10,000 small spoonfuls of sand later and you'd have a solid speaker standafterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
ooop. yup they sure are. ok, so in the descriptions I have read about these stands, you could fill the tubes to alter mass.... not this model of stand?Aren't those "fill holes" for running the speaker wire through?Polk Lsi9
Keces DA-131 mk.II
best as I can tell, if i want to fill the front tube with any sort of efficiency, i'll need to drill out a bigger hole in the top center plate of the tube. then I could use a small funnel to fill with sand.Polk Lsi9
Keces DA-131 mk.II
