5JR+ and Pangea speaker stands
11tsteve
11tsteve Posts: 1,166
edited May 2014 in Speakers
This may or may not be a stupid question, but here goes....
Just got and assembled the Pangea Ls200 28" stands, and I am curious if anyone ever drills a hole in the speaker base and maybe drops a screw through to the bottom of the speaker cab. I KNOW I KNOW it seems like sacrilege to do that to the speaker, but man, I know I am going to have a hard time trusting such a small plate for the speaker to sit on....
I am probably over thinking this?
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2
  • Dawgfish
    Dawgfish Posts: 2,554
    edited May 2014
    Use some blue tack between the stands and bottom of the speakers. It makes a more secure connection.
    edited May 2014
    My opinion, those stands are too high. Which ones did you get ? Post a link bro.
  • Mystery
    Mystery Posts: 2,546
    edited May 2014
    Blue tack or Velcro, no holes...
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited May 2014
    Cut a propper size foot plate ( wood or whatever) bolt that to the stand and "place " the speakers on the "new plate" or just but the propper size stands.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    edited May 2014
    I was going to suggest that...^^^, but depending on the stand it could make it top heavy and prone to tilting over. That's why I asked which stand he bought.
  • 11tsteve
    edited May 2014
    These here Tony.
    http://www.amazon.com/gp/product/B00GLX7S00/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
    That puts the tweets just at ear height when I am sitting at my desk. And I was thinking of filling the tube, though not sure with what yet. I find is odd, though, that there is a fill hole at both ends of the tube, and no type of stopper provided.
    I have rebuilt crossovers, but the stupid stands just befuddle me.
    and thanks everyone. I really didn't want to screw through my fresh veneer....but I wasn't sure if it was considered any different than drilling in spikes.
    Polk Lsi9
    Keces DA-131 mk.II
  • Nightfall
    Nightfall Posts: 10,083
    edited May 2014
    Aren't those "fill holes" for running the speaker wire through?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Nightfall
    edited May 2014
    Haha, one of the Amazon reviews talks about just that.
    The biggest disappointment for me is the inability to fill either of the columns with sand. The description of the stand describes the option to fill the columns with sand, but honestly, the only way I could envision adding sand to the columns would be with an eye dropper or a tiny spoon, as the only opening is very, very small. 10,000 small spoonfuls of sand later and you'd have a solid speaker stand
    afterburnt wrote: »
  • 11tsteve
    edited May 2014
    Nightfall wrote: »
    ooop. yup they sure are. ok, so in the descriptions I have read about these stands, you could fill the tubes to alter mass.... not this model of stand?
    Polk Lsi9
    Keces DA-131 mk.II
  • 11tsteve
    edited May 2014
    best as I can tell, if i want to fill the front tube with any sort of efficiency, i'll need to drill out a bigger hole in the top center plate of the tube. then I could use a small funnel to fill with sand.
    Polk Lsi9
    Keces DA-131 mk.II
