another cable question
BKphoto
BKphoto Posts: 409
edited April 2014 in 2 Channel Audio
What do you guys think of coax cables with rca's attached...There is a guy on fleabay who makes them and has a good rep, says they work great....
what say you...?
Brent
Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Post edited by BKphoto on
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2014
    How many cable manufacturers offer those for sale? Zero? One? I think that gives a clue as to the benefit of putting RCA connectors on coax.
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    thats why I'm asking...seemed odd...
  • 11tsteve
    11tsteve Posts: 1,166
    edited April 2014
    BlueFox wrote: »
    Morrow, Audioquest VDM-1, Grover Huffman... Douglas cables... all have RCA. Am I misunderstanding the question?
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    Is it a good choice for analog audio or no...?
    txcoastal1 Posts: 13,513
    edited April 2014
    BlueFox wrote: »
    Dynaudio Ocos speaker cables are a coaxial design
    http://www.dedicatedaudio.com/inc/sdetail/27046
  • BlueFox
    edited April 2014
    11tsteve wrote: »
    They use coax? The same cable as for cable TV?
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited April 2014
    Coax is a cable design not exclusive to TV cables. Center conductor with full outer shield carrying a signal. This is different than a pair of identical conductors carrying the signals in a paired design.
    F1nut Posts: 51,782
    edited April 2014
    BKphoto wrote: »
    The only coax with RCA's I've seen are sold as a LFE sub cable.
  • RamZet
    RamZet Posts: 792
    edited April 2014
    I will only use this if I have no other option and the wires I ran (in-wall) for a sub are picking up a hum from romex.
    They are very well shielded, but not my ideal cable for anything.
    I would look at Interflex by Liberty. Its like a fancy RG59 for audio. http://www.libertycable.com/products/Liberty-Wire-and-Cable/INTERFLEX/Line-level-audio-non-rated-cable-for-interconnect-manufacture
    B&W CM9Classé Sigma
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    i was just bouncing around ebay and saw it...Sent him a quick email just to see if they are used for audio and he said yes...Again I thought it was odd, I'm not buying anything, just wondering...
  • dragon1952
    dragon1952 Posts: 4,907
    edited April 2014
    Blue Jeans audio cables are coax designs. The good thing about coax is that it is typically a solid core conductor which many believe is superior to stranded cable for unbalanced audio cables.
  • FTGV
    FTGV Posts: 3,650
    edited April 2014
    75 ohm Coax can be used for IC duties.The stranded core Canare LS61 is a great digital cable but also functions well as an analog IC.
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    dragon1952 wrote: »
    I forgot about that, I've heard a lot of good things about those cables...
    SCompRacer Posts: 9,112
    edited April 2014
    BKphoto wrote: »
    what say you...?
    Brent
    They absolutely do work great. And yes, I have tried high end cables from big name makers. I used coax IC's for years until I went all balanced due to a diy DAC. Usually stranded center wire coax is used as they are more flexible than a solid center conductor.
  • BlueFox
    edited April 2014
    Good thread. I am learning something. I have never heard of coax (which in my mind is cable TV cable) being used for analog interconnects, which is how I interpreted the question. I do have a Blue Jeans custom coax cable with RCA on one end and BNC on the other, but it is a digital cable to connect my Wadia iTransport to a Benchmark DAC.
  • 11tsteve
    edited April 2014
    the Audioquest 75 ohm digital cables are a solid conductor, and I believe my Huffman digital IC is as well.
    Polk Lsi9
    Keces DA-131 mk.II
  • headrott
    headrott Posts: 5,496
    edited April 2014
    Also, Chris Venhaus uses 75 Ohm coaxial cable that can be used for digital or analog IC's. I used this in my DAC andhave made a digital cable out of it. It is fantasic wire!
    Link: http://www.vhaudio.com/images/pulsar-ag-occ-silver.jpg
  • mantis
    mantis Posts: 17,408
    edited April 2014
    The Coax designed cable is used for many different applications. It has extremely high band width and can carry multiple different signals at one time.
    In todays market, customer Installers use this style cable for sending cable signal around ones home. With those cables in place we can also send network signals on top of the cable signal with a Balun device. So with one cable you can have cable service and network service at one location. Pretty damn badass.
    Years ago the coax cable was used for DSS signals from the Dish to the box. Over this same cable you can send a Roof Top Antenna signal on top of the DSS signal with a special 2 way splitter on both ends. It has a power pass for the DSS and a pass through for the Antenna feed. Both signals work perfectly over the one cable.
    Now for long Subwoofer runs in wall and what have you, the Coax cable is again used here. It has the ability to send the Subwoofer signal long lengths with excellent results.
    I have used both twisted pair and coax designed built subwoofer cables and I have never noticed a difference in equal quality cables.
    All Digital coax cables are designed out of Coax cable. When properly terminated , it meets spec of 75 ohms.
    All proper analog video cables are coax design.
    Full bandwidth analog pass is not ideal over a Coax designed cable as it's resistance is higher then spec. Coax is 75 ohms and analog spec is between 44 and 50 ohms depending on who you talk to. This is a very gray area where no one agrees on what the exact proper unbalanced spec is. I have tried for years to learn what this is and I always get different answers.
    Now personally I have used coax designed cables with excellent success. The higher ohm resistance doesn't seem to effect performance volume or anything I have noticed. But most cable companies use twisted pair design mostly for analog transmission. But some of those same companies will use a custom built coax design cable for analog as well.
    Audioquest has a custom ITA line which uses a Coax design. It has a solid core conductor but the negative or shield is different. It's made out of solid core conductors instead of the coax braid. They do however use the braid on the custom built video cables which I have tested for audio and didn't notice any performance loss or gain or that matter.
    I think why over the decades of cable threads go south it due to the fact there is to many opinions on how to get these signals from A to B properly. You ask 10 different companies the right questions and 10 different answers you will get. I know this from professional experience as I tried to unravel the truth behind cable design and getting the job done.
    One thing I did find that seems to hold true to most companies is this.
    1) Quality of metal effects the transmission of a signal.
    2) Dielectrics effect proper signal pass.
    3) Geometry of the conductors effect signal pass.
    4) Properly terminated cables effect the signal pass.
    So basically breaking it down to the bare essentials no matter who what or why a cable is designed for a purpose , that cable needs to be able to pass the signal from the source to the end point unaltered. All cables add distortion of some kind as they have to be in place to carry the signal. The real goal to minimize this loss and not pick anything up along the way.
    Dan
  • CoolJazz
    CoolJazz Posts: 572
    edited April 2014
    Lots of coax is copper clad steel. Steel sucks for audio.
    Be careful thinking you can pick up just any coax and believing you're going to make diamonds from ordinary rocks.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    tonyb Posts: 33,072
    edited April 2014
    CoolJazz wrote: »
    CJ
    Amen to that...not all coax cable is created equal.
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    RG6 is a good coax....
    correct...?
  • zane77
    zane77 Posts: 1,696
    edited April 2014
    Coax comes in many flavors. Here' same short story.
    http://www.belden.com/blog/broadcastav/50-Ohms-The-Forgotten-Impedance.cfm
    Two Channel
    edited April 2014
    BKphoto wrote: »
    correct...?
    Not to say what good or not good, but I will say as Tony has said not all coax is created equal. I install CCTV for a living and there is a lot of sub par coax. Many manufacturers don't use all copper or the braid is of cheap copper.
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    txcoastal1 wrote: »
    I see, Yeah that stuff is copper "clad"... not interested....but I definitely learned something today....since I'm stuck here with 2 sick kids...
