Monitor 70 power question
Smilligan66
Hey guys. I'm looking for advice on my receiver power. I just bought a yamaha rx-v775 receiver. I just found a great deal in monitor 70's and am wondering if my avr is powerful enough to run them well? Or do I need a seperate amp to make them sing. Thanks in advance.
Your receiver is fine to power them, but any speaker will benefit from a separate amp.HT SYSTEM-
lsi 9's -
+1 esp the 70'sMarantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
Welcome.
You should be fine in a standard size 300-400sq foot room with listening levels up to 85 db.
Remember the louder and more bass your sound requirements, power needs increase exponentially.
Also using a powered sub woofer with a 90 Hz crossover helps a lot,
a PSW-505 is a good match a can be found on sale for less than $200 shipped.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
The 70s will sound great on almost any size amp, they dont take much to drive.B&W CM9Classé Sigma
