Monitor 70 power question
Smilligan66
Smilligan66 Posts: 6
edited April 2014 in Speakers
Hey guys. I'm looking for advice on my receiver power. I just bought a yamaha rx-v775 receiver. I just found a great deal in monitor 70's and am wondering if my avr is powerful enough to run them well? Or do I need a seperate amp to make them sing. Thanks in advance.
    edited April 2014
    Your receiver is fine to power them, but any speaker will benefit from a separate amp.
  • Geoff4rfc
    Geoff4rfc Posts: 3,062
    edited April 2014
    +1 esp the 70's
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
  • PolkieMan
    PolkieMan Posts: 2,446
    edited April 2014
    Welcome.
    You should be fine in a standard size 300-400sq foot room with listening levels up to 85 db.
    Remember the louder and more bass your sound requirements, power needs increase exponentially.
    Also using a powered sub woofer with a 90 Hz crossover helps a lot,
    a PSW-505 is a good match a can be found on sale for less than $200 shipped.
  • RamZet
    RamZet Posts: 792
    edited April 2014
    The 70s will sound great on almost any size amp, they dont take much to drive.
    B&W CM9Classé Sigma
