Interesting Polk Speaker Modification!
gudnoyez
http://quadcities.craigslist.org/ele/4413327375.html
And these could be all yours for $75 the stuff you see on CL wonder what model these modded polk speakers these are? Make sure you look at the second picture speaker on the left.
Post edited by gudnoyez on
I like how the grill just flips down to show off the modification.Home Theater
Polkfrankenstein...
Looks like some hot rodded RT12s (?).
Very nice...I think that flip-down grille was only an option on the Platinum model. -
May be it was $75 but now it's $40???
I did the opposite... dropped in Polk tweeter in Klipsch RF3.
I either added Klipsch RF3 to the Polk tweeter or added Polk tweeter to Klipsch RF3.
Either way...
Hehe... it's temporary just for testing as the Klipsch tweeter is toast. The SL-2000 does produce highs but is not as efficient as the Klipsch tweeter.
that's one way to kill a thread...
Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
Mains: 2x Polk RTA 8TL's
Center: Polk CS245i
Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
Rear Surr: 2x Polk M4a '90
Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
Display: Samsung 55" UNC55-8000 3D LED
Console: Xbox360
DVR: custom MythTV rig w/ 3 tuners OTA
Zone2: 2x Polk M5b '87 -
Even the SL2000 probably sounds better than a Klipsch HornI did the opposite... dropped in Polk tweeter in Klipsch RF3.
Either way...
Home Theater/2 Channel:
dhsspeakerservice.com/ -
You are probably right, especially with the heritage series horn.westmassguy wrote: »Even the SL2000 probably sounds better than a Klipsch Horn
I've had both Heresy and KG4 (KG4 is much better sounding than the Heresy IMO) and they are too bright but the KSP-400 and these RF3 are much less compared to them.
I enjoy KSP-400 without noticing any harshness that I noticed on Heresy and some on KG4.
I'm ordering soft dome tweeter diaphragm for the RF3 that are supposed to be smoother/better than the titanium one so we'll see.
More open mid range. Bass comparison is not suitable as they use active drivers in ported cabs vs PR in Polks.How do those woofers sound, compared to the Vintage era Polk midwoofers?
