Internal vibrations of the capacitors...
Aroundthesuond
Aroundthesuond Posts: 37
edited April 2014 in DIY, Mods & Tweaks
hello to all,
Today while I was doing breakin of two caps, a strange thing happened.
When I raise the volume, approaching the ear, the capacitor plays the song that is playing!
Is ike a very low sound and a bit distorted/smothered.
The two capacitors are a claritycap MR and a mondorf Silver/oil
At high volumes, the capacitor that further develops this phenomenon is the MR CC, the Mundorf sounds less.
I think it is due to higher internal resonances of the CC MR.
But, how is it possible that the CC MR vibrate more of the silver/oil ?
Claritycap is famous for the studies done by the industry to break the resonances ​​!
This is a strange thing.
What do you think?
  • Speedskater
    Speedskater Posts: 495
    edited April 2014
    I think that it's a good reason for not buying handmade boutique capacitors.
    A audio forum moderator (tubes) whose day job is in this field, writes:
    High Grade Caps
    I'll come out in the middle. You want a high quality cap with low microphonics, ESR commensurate with the crossover requirements, and relatively low inductance. That means encapsulated, machine-wound caps, high tension windings, with polypropylene being the preferred dielectric. Metal foil would be preferable to metallized.
    Avoid any cap labelled "audio" or "audiophile" or any cap boasting of exotic materials- that usually degrades performance, which makes some audiophiles happy because of the added distortion and microphonics.
    Stick with well-engineered mass-produced brands. Wima, Vishay, Panasonic, that sort of thing.
  • Phasewolf
    Phasewolf Posts: 514
    edited April 2014
    How were the caps installed on the board? They need to be zip tied down tightly as the least. Also I have seen all kids of caps sing nothing new there.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • Aroundthesuond
    edited April 2014
    my question is different.
    CC MR have behind one large study in collaboration with companies of speakers, to break down the internal vibrations
    the Mundorf silver / oil does not have this type of study
    my question is: why the CC MR resonate more than the Mundorf s/o if approach my ear to the capacitor ?
    the study of claritycap is not served its purpose?
  • Phasewolf
    edited April 2014
    Because of how the internal structure is formed how the cap is constructed and many other things play a part. Anyway you look at it the caps need to be firmly secured to the board if they were not during your testing.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Polk F/X500i Rears
    Parasound HCA-3500
    F1nut Posts: 52,406
    edited April 2014
    What a crock of ****.
  • embrown057
    embrown057 Posts: 46
    edited April 2014
    OP, please disregard the second post, this post was a quote from "one of those Nut's" that can either afford quality caps of is vastly ignorant on the subject or possibly tone deaf. I believe F1 was doing his best to rely this. If you film cap is "singing" to you I would check all your solder connections and traces for cracking. It is NOT normal for a capacitor to "self oscillate".
  • Aroundthesuond
    edited April 2014
    why, in the same condition, CC MR sing more then munforf s/o ?
    perhaps the CC MR are not as good as they say?
    F1nut Posts: 52,406
    edited April 2014
    What are they mounted to and how are they mounted? Where are they located? Why are you burning in two different brands of caps?
  • Aroundthesuond
    edited April 2014
    are mounted very firmly
    I'm testing them, and they are on wood support
    but that got to do this question?
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    do you listen to music or are you just into the science part of this hobby...?
    I mean no offense, just trying to figure out where you are going with this test...
    Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
  • 11tsteve
    11tsteve Posts: 1,166
    edited April 2014
    what is the speaker being tested and where are the caps in the crossover circuit?
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • Aroundthesuond
    edited April 2014
    caps are in the same position
    one is switched with other
    treitz3 Posts: 20,363
    edited April 2014
    Cryptic writing techniques, not answering direct questions asked to you shows a complete lack of respect for those who are trying to help you out. Get with the program or stop trolling.
  • Aroundthesuond
    edited April 2014
    treitz3 wrote: »
    really i don't understand, my question is clear, so my words already written :
    "my question is different.
    the study of claritycap is not served its purpose?"
    not my fault if you do not understand
  • Face
    Face Posts: 14,340
    edited April 2014
    Who listens to the capacitors themselves?
    How about testing and judging them by listening to the speakers they're connected to?
  • bikezappa
    bikezappa Posts: 2,463
    edited April 2014
    Strange but I totally agree with your statement.
  • Speedskater
    edited April 2014
    Just guess whose opinion I'll go with?
    http://syclotron.com/?cat=9
  • 11tsteve
    edited April 2014
    you didn't answer my questions. What speaker, where in the crossover circuit do they reside.
    Polk Lsi9
    Keces DA-131 mk.II
  • polk500
    polk500 Posts: 1,171
    edited April 2014
    Toolfan66 wrote: »
    Love it,
    That sir is priceless.
    Thanks for posting it will be on my office computer home page come Monday morning.
    Cheers
    Roger
    And sorry to the OP don't intend to offend anyone.
    F1nut Posts: 52,406
    edited April 2014
    What caps have YOU tried?
    F1nut Posts: 52,406
    edited April 2014
    I'm going to suggest you contact Clarity. I'm sure they would interested in your findings.
  • Face
    Face Posts: 14,340
    edited April 2014
    Maybe that they'll explain that you're supposed to be using speakers to listen to music, not the caps themselves? :D
  • Speedskater
    edited April 2014
    The ones the SY recommends would be a good start.
    It take's big manufactures with big expensive machines and a big quality control department to make good capacitors.
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    Face wrote: »
    that was my point...
    Its like the "burn in" thread....
    F1nut Posts: 52,406
    edited April 2014
    You can keep side stepping, but your lack of experience will still shine on like a beacon in the night.
  • halo71
    halo71 Posts: 4,645
    edited April 2014
    Are you being sarcastic or do you really believe that? Just asking...
    --Gary--
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited April 2014
    Hello,
    There can be a combination of circumstances where a capacitor can be microphonic or piezoelectric. For example a signal capacitor in an amp carries an AC signal, but if it has a DC voltage on one side it can behave like a condenser microphone. The DC voltage polarizes the capacitor and the AC signal becomes the vibrating source.
    In other words, no, it's not unusual for capacitors to be microphonic.
    Regards, Ken
  • Aroundthesuond
    edited April 2014
    thank you very much for your reply, kenneth,
    I would like to understand why the CC MR are more microphonic/piezoelectric than mundorf silver/oil
    should be less than the others, but isn't so, why, from your point of view ?
    CC has done an extensive research on internal vibrations of caps...
  • [Deleted User]
    edited April 2014
    Hello,
    I'm afraid I don't have the definitive answer for you, I've not had any experience with either brand. For most critical listening I have found the V-Cap to suit my taste. The only guess I could make would be whatever winding technique one company uses could be more effective in damping out the vibrations.
    The Elna company talks about vibration damping in their SILMIC series capacitors, which I find sound very good.
    "At Elna, we have moved forward with development activities based on the perspective that this "softness" of silk can mitigate vibrational energy, which is generated from the electrodes in the capacitor. Also, this silk softness will mitigate the vibrational energy of the music propagating through the air and striking the capacitor."
    I know of speaker designers who use oil filled motor running capacitors in their crossovers due to the very rigid metal frames they have and the relatively large container of oil that houses them. Granted they are large to use, but if size were not an issue they can be quite nice.
    Cheers, Ken
  • gmcman
    gmcman Posts: 1,887
    edited April 2014
    I once drove my mom crazy by hooking up an RC car motor to an old beater stereo through the speaker wires and left it on the dresser...she was going nuts trying to find out where the sound was coming from. :smile: You could easily make out the song but needless to say at a lower volume.
