Adcom GFP 565 710 715 differences?
geppy1
geppy1 Posts: 3,076
edited March 2014 in 2 Channel Audio
Hi, I am now using a Adcom 565 which seems rather inpressive compared to other Adcom units (tuner preamps) I have tried but would really like a renote. The 710 and 715 come with remote . What is the difference soundwise between the 710 and 715? The other thing I cannot help but wonder about is that the 565 was $800 in the late 80s and the 710,715 ran $600 years later and came with a remote Something has to give here. Is there a drop in sound quality from the 565?? Thanks
Post edited by geppy1 on
  • erniejade
    erniejade Posts: 6,321
    edited March 2014
    I can't speak for the other units but the 565 sounds awsome especialy for the $. The phono pre in it is also way better then one would expect.
  • geppy1
    geppy1 Posts: 3,076
    edited March 2014
    Really would like a remote but do not want to go backwards.
    edited March 2014
    According to Polk forum archives. The best Adcom Pre is the GFP-750.
    After that the GFP-715 is considered next in line though it is nowhere near as good as the 750.
    cnh
  • geppy1
    geppy1 Posts: 3,076
    edited March 2014
    What is the difference between a 710 and 715?
