I've had this idea for years, what do you think?
mantis
mantis Posts: 17,473
edited April 2014 in The Clubhouse
One day I would like to build a museum.
What would it be like? Well read on.
I want to build a Audio video museum. You would come in and start at the very beginning of replay systems. Learning about how they where built, who where the Pioneers and how we got to where we are now.
I would have a full wire history, why better wire was thought of, who started it all, who is the very best at it and how all others have grown over the years etc.
A Speaker journey from the earliest models to todays amazing offerings.
A amp journey that would take you through a full learning and touching experience. Learn why famous Amp builders etc.
A full Home Theater journey where you would learn how Dolby Surround was introduced and how it became Prop Logic then DD and so forth. How DTS and Sony got into the picture etc.
I would have rooms you would walk into during the tour that you would sit on furniture from that time period and listen to music and systems all wired and working the way they where supposed to be then and now.
I would have glass cases with remarkable gear in it to look at and learn about. This could be a place for all fans of home replay systems to come again and again.
One day I would love to make this real.
Dan
Post edited by mantis on
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited March 2014
    Very cool idea.
    mhardy6647 Posts: 35,050
    edited March 2014
    ... of course... the last exhibit has to be a little phone and a pair of earbuds...
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2014
    If you do it, you've GOT to have a special wing of the museum called "Do Cables Really Matter?" And then prove that, once and for all, they do. Or do not.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited March 2014
    You need to devote an entire room to the remarkable story of Vladimir Zworykin, who for all practical purposes, was the inventor of television.
    Clipdat Posts: 13,095
    edited March 2014
    I would visit said museum.
    Weekly.
    edited March 2014
    Interesting idea that would FAIL market testing big time, so I hope you win the lottery and have the cash to make it happen because otherwise there would be no way to keep it open! And only a lot of balding, bear-belly, T-shirt and Mom jeans wearing (barely fitting) 40 somethings and above would ever make the trek! lol
    cnh
    txcoastal1 Posts: 13,513
    edited March 2014
    cnh wrote: »
    cnh
    Ouch, but probably correct, would have to be located near other museum type or rock-n-roll HOF
    Could operate as non-profit w/grants etc
    tonyb Posts: 33,072
    edited March 2014
    mantis wrote: »
    Hmmm....and in that last glass case, at the very end....rest an Ipod. Tour is over.
    Dan, nobody cares bro, isn't that painfully obvious by now ? Except for a few in the niche markets of Audio, the rest are happy with Ipods, earbuds, and streaming music to a 300 buck AVR.
    F1nut Posts: 51,802
    edited March 2014
  • DracoAmericanus
    DracoAmericanus Posts: 112
    edited March 2014
    Don't for get Farnsworth he had a lot to do with early television.
    I have an example of an early sub woofer called at that time an acoustical labyrinth, with woofers that used leather for the surround, Stromberg Carlson 1936. it vents facing the floor, I have a "mostly" working color tv from 1961 as well, with the remote. if you have a forklift we could put that in the museum as well
    There is no cure....
    Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
    8mm, 7.62x39mm
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited March 2014
    I'd go.
    Would you have a special wing dedicated to the quality audio research and accomplishments of Dr. Amar Bose?
    :D
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited March 2014
    ROHfan wrote: »
    This wing could be a tunnel that gets smaller and smaller towards the end with the high-end cables...
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • DracoAmericanus
    edited March 2014
    should charge a high and higher charges as the tunnel gets smaller too
    8mm, 7.62x39mm
    edited March 2014
    ... just don't forget Philo T. Farnsworth...
    (EDIT: ahh, someone else remembered ol' Philo, too... good!)
    txcoastal1 wrote: »
    hmm... R&R HOF... not a bad idea... opportunities for cross-promotion...
    CN from AK by mhardy6647, on Flickr
  • xjghost
    xjghost Posts: 1,115
    edited March 2014
    That is quite cool. OP: maybe contact tv and audio companies. It could be done. IF you have the organizational skills and can talk turkey I bet you could get quite a few companies on board with this.
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
    edited March 2014
    There are myriad small/private museums in the US. Some of them are extremely modest; some of those are extremely interesting.
    Here's an in-between example, not quite on topic but still related to media/the fine arts... related to... ;-)
    www.museumofbadart.org
    Peter the Kitty
  • Tornado Red
    Tornado Red Posts: 939
    edited March 2014
    Wow, that's quite a collection! Though I don't know how complete it is, I mean I didn't see ANY Bose or Emo gear....
  • DracoAmericanus
    edited March 2014
    thr twp tv pioneers did steal ideas from each other buy we would not have it as we know it, i have a nigh vision gen 0 from farnsworth that is a bit complicated, it's NOS and i store it in the box to protect the photo cathode from light as i am told on the old ones can degrade in light. I have a B/W reel to reel video recorder i could add as well, of it would be great ballast for a boat, some of the neat things can be had for free if you know the right shows. i know it's all crap to us, but we tend to be the oddities that save this crap so others can enjoy and joke about laster, history needs to be keept even is it's just that red jvc camcorder from the movie" back to the future", mine still works with the battery subbed, first gen iPods i think a few should be saved as well
    I dont know if it's my dragon hording kicking in but a few people should save that crap
    8mm, 7.62x39mm
  • sucks2beme
    sucks2beme Posts: 5,686
    edited March 2014
    When Farnsworth developed early tv, RCA made him an offer.
    When he said no, RCA tied him up with lawyers for years.
    He ended up broke, and gave in. Looks like RCA and Microsoft
    share common business models.
    edited March 2014
    sucks2beme wrote: »
    Microsoft's - and even Apple - have got nothin' on Sarnoff and RCA...
    http://www.pbs.org/wgbh/amex/technology/bigdream/masarnoff2.html
    http://fecha.org/armstrong.htm
    Poor Gen. Armstong - inventor of FM radio as we know it to this day - was driven to suicide by Sarnoff's practices...
    SCompRacer Posts: 9,112
    edited March 2014
    There is a forum member here in New England that has a good start on the audio end....;)
    EDIT: My bad, more than a good start....
  • steveinaz
    steveinaz Posts: 19,545
    edited March 2014
    Audio museum man cave?
    edited March 2014
    LOL Man caves over the years....I'd be in.
    nooshinjohn Posts: 25,932
    edited March 2014
    Great idea, just keep PFB out. That would be like inviting a Brahma Bull into a china shop filled with Ming Vases.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited March 2014
    Well I think this idea is pure genius Dan, if there was ever a place it would be on my map as one of the top ten museums to visit.
  • zingo
    zingo Posts: 11,258
    edited March 2014
    He he he
    edited March 2014
    Heck no; he's in charge of procurement and logistics.
  • madmax
    madmax Posts: 12,434
    edited March 2014
    Hopefully it has a large Victrola room, that is where all the cool people will hang out.
    Vinyl, the final frontier...
    edited March 2014
    Indeed. Excellent.
    Perhaps they'll have a Webster wire recorder, too. How frightfully infra-dig that would be.
  • George Grand
    George Grand Posts: 12,258
    edited March 2014
    cnh wrote: »
    The last glass case should have a group photo of everybody BUT the above-mentioned niche (but with beer guts, not bear guts).
