What Subwoofer?
My question is the subwoofer. I have an older Velodyne CHT12 which I am currently using and it sounds ok, but is only rated at 170watts. An audio friend suggested I look into a Polk PSW 505 which is rated at 300 watts. There is a refurbished one on e-bay for under $200.
Is the PSW as great as suggested? What other Subwoofers would work well with this system? any suggestions. Also would you go
refurbished with a subwoofer?
My system is a Denon avr 4520 ci and Polk rtia7's bi-amped, csia6 by-wired and rt600i in back.
  • ken brydson
    ken brydson Posts: 9,097
    edited March 2014
    Sky's the limit depending on your budget. How big is your room? Mainly HT or music too? The 505 is a great entry level HT sub but it's not particularly "musical".
  • invester
    invester Posts: 6
    edited March 2014
    I like music more then HT, however, I do like some light classical music with some bass and movies like Phantom of the Opera
  • invester
    invester Posts: 6
    edited March 2014
    My family room is about 20' x 30' with a fireplace and bookshelves in back.
  • ken brydson
    edited March 2014
    That's a pretty big room. What's your budget?
  • rpf65
    rpf65 Posts: 2,127
    edited March 2014
    That big of a room, look at HSU VTF-15 or SVS SB-13 or PB-12 plus. Of course if you can go bigger, that never hurts.
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2014
    That might be a candidate for dual subs.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
