the thicker the better?
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    edited March 2014
    Jayce1971 wrote: »
    Thought this was cool. You can actually audition different interconnects and speaker wires, and decide in your home, with your equipment, whether or not the cost is justified. Surprised I hadn't seen this sooner.
    http://news.cnet.com/8301-13645_3-57582757-47/can-expensive-audio-cables-improve-the-sound-of-a-hi-fi/
    I had no idea we were looking for an improvement, I've only seen where people can't hear a difference, that's the only argument I've ever heard. $100000 improvement is what I want!!!
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • mantis
    mantis Posts: 17,526
    edited March 2014
    1312DN wrote: »
    hello
    i have a question, for wiring speakers a thicker wire for the speakers is better than thiiner speaker wires?
    i have the question because i do not know if a thicker cable would ensure to me a better sound quality or more detail on music and movies or just do not matter if the wire is thicker or not.
    best regards
    Frank
    Frank,
    There are some things to consider when buying speaker wire. Thicker isn't better or worse , it's correct or not. Just to start out you need a certain gauge of wire to send the signal a distance , ohms of the speaker and power of the amp all factor into this.
    Example:
    Lets say you have Polk speakers in the RTia series. They are rated at 8 ohms. You are running them with a 100 watt amp. Your speaker lives 10 feet away. And then IF you are running full range which most polks can't handle full range, your going to need 16 gauge wire based on copper. If you went Silver you could get away with 18 gauge. Going with 14 gauge wire in copper is fine at 10 feet , slightly overkill but won't cause excessive resistance as actually it will have less.
    If you have a more powerful amp, then heavier gauge wire will be needed. Wasting your money and time on super heavy gauge wire will not improve anything. Now quality is a totally different story.
    I strongly suggest learning the AWG standard first , then moving onto quality. You got to get the gauge right first , once thats achieved , you can improve on sound quality with better quality materials.
    I also suggest using wire thats actually designed to do the job , not using any old kind of wire. Geometry of the conductors is so important to sending the signal correctly.
    Dan
  • czarodzi
    czarodzi Posts: 38
    edited March 2014
