Crossover question (Monitor 5JR+)
On3s&Z3r0s
On3s&Z3r0s Posts: 1,013
edited March 2014 in Vintage Speakers
I've been doing some XO upgrades (inductors) on a pair of SDA-2B's and since I was ordering parts and was going to have the iron warmed up I figured I'd play with a pair of Monitor 5Jr's I had upgraded a couple of years back. They were the first series 5Jr+ with the PR and the SL2000 tweeter. I had put a Dayton 12uF cap in them and RD0-194's.
For this latest round of changes I decided to try the RD0-198's in them. So, I got two 12uF Sonicaps and two 1.5uF to make the 13.5 (figuring if I didn't stick with this configuration it would be easy to repurpose the 12s). I just reused the stock PCB and paralleled the 12 + 1.5 combination. So, I have two questions:
First, I'm less than 10 hours into burn-in, but the 198's seem significantly louder than the 194's so far. They're definitely also more detailed, but right now it kinda sounds like the MW-6502's are going to have a hard time keeping up. I'll keep burning in and reserve judgment for a few more weeks, but when I burned in the 198's in the 2B's, I don't remember them getting significantly quieter. Very different speaker obviously. If they don't get quieter I was wondering what it would do to increase the capacitance on the small cap to get say 14uF in that spot instead of 13.5? Likely to make any difference? Or is paralleling one large(ish) and one small cap like this just doomed to fail for some reason?
Second, I was noticing that in the Series II Monitor 5Jr schematics the polyswitch has been removed. I checked out a couple of pics recently posted of the stock version of that crossover (http://www.polkaudio.com/forums/showthread.php?158435-Thrift-store-score-M5jr-series-2&p=2017282&viewfull=1#post2017282) and sure enough, no polyswitch I can see. I had put a .5ohm Mills resistor in the spot for the poly in the earlier crossover I have. Based on the location of the polyswitch in that design it seems like it's on the path to ground from the tweeter. So, could it possibly be having any effect on the sound either way, or should I just pull that out and jumper it?
Thanks, as usual, for the expert advice!
Post edited by On3s&Z3r0s on
