MW7203 vs 7204? Differences?
Inspector 24
Inspector 24 Posts: 1,308
edited March 2014 in Speakers
Bought a bunch of speakers, the CS400i that came with them has a blown mid/woofer, it's part number is MW7204, I have a spare MW7203 which appears the identical save for a slight difference in cone color.
Same woofer different part number?
EDIT: Nevermind, I'm too anxious to post, they're different, appears the 7203 has a second magnet stacked on the back:
Purpose of the double stacking? Should be ok to toss in the CS400i with the other MW7204 right?
Ryan
Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500
Post edited by Inspector 24 on
  • ken brydson
    ken brydson Posts: 9,003
    edited March 2014
    Probably a bucking magnet to shield interference from older CRT's...
  • Inspector 24
    edited March 2014
    Aaah, so it's like a secondary shield to the metal cap that? Or since the 7204 was newer, maybe they decided the 2nd magnet wasn't needed?
    If so sounds like I'll be fine...Right? If so look for this in the classifieds soon. :razz:
    Up
    Down
  • ken brydson
    edited March 2014
    That's my guess, might check with CS to find out for sure. I do know when I ordered a replacement driver for one of my LS50's it came with the extra magnet. I called Ken S and he told me that was the difference.
  • Inspector 24
    edited March 2014
    Got it. Well it's all back together and sounds fine, so thanks for the advice!!!
    Up
    Down
