WTH is Slope Control???
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
I was looking at the back of one of the subs at Ultimate last weekend...it was the KEF 2150 and found something new to me...
There is a switch called "slope control" marked 12/24dB that is not explained. Do you have any idea what this is for?
The KEF web site gives few details.
Post edited by AsSiMiLaTeD on
  • gatemplin
    gatemplin Posts: 1,595
    edited July 2004
    It probably changes the crossover from 2nd order (12 dB per octave) to 4th order (24 dB per octave). It would add flexibility and could be useful depending on what speakers you use.
    Graham
  • AsSiMiLaTeD
    edited July 2004
    Can you expound just a bit? When you say "2nd order (12 dB per octave)"...what does that mean?
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited July 2004
    All filters have slopes (i.e., how quickly they ramp down the signal). Slope is measured in units of dB/octave.
    The steeper the slope, the higher the order of the filter.
    1st order = 6 dB/octave
    2nd order = 12 dB/octave
    and so forth.
    Typical low pass filters on subwoofers are 4th order, but most AVR's impose a 2nd order high pass on the mains, and there is a mismatch of slope. The ability to alter the slope of the filter to achieve parity with the corresponding high pass is a really nice feature.
    Doc
    SVS
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2004
    Man, there is a friggin HILARIOUS answer to the intial question, but I can't bring myself to post it.
    Cheers,
    Russ
  • TroyD
    TroyD Posts: 13,124
    edited July 2004
    Life is suck
  • AsSiMiLaTeD
    edited July 2004
    Cheers,
    Russ
    well let's hear it then...
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited July 2004
    Cheers,
    Russ
    I was thinking the same thing ... but I don't think I'll go there ...
  • Pauly
    Pauly Posts: 4,519
    edited July 2004
    Freakin Spec...Name says it all..
    Pauly
    Life without music would
