Hooking up new HT system
Andrew R
Andrew R Posts: 2
I have recently started acquiring Polk Audio gear to complete my HT system. As of now, I have two Polk R40s fronts, a CS10 centre channel, RTi A3s for rear and a PSW10 subwoofer; using a Marantz SR 5003 for my receiver.
Coming from a DJ setup consisting of solely studio monitors, I am finding it a little difficult to hook everything up together. As I already know, the PSW10 doesn't have an LFE, only speaker level input and line in. I am wondering how I should hook up the subwoofer - should I use speaker wire, or use a Y adapter from line in to the subwoofer out or is there a left and right on the receiver as well that I could plug the line in on the subwoofer to.
I have just purchased speaker wire and banana plugs online, as I like the ease of plugging and unplugging, as opposed to the tradition bare wire way.
If anyone has any suggestions of tweaks/settings/ways to boost the performance of my system, I'm all ears!
Post edited by Andrew R on
  • quicksilvergts
    quicksilvergts Posts: 274
    edited February 2014
    Good Morning,
    Welcome to Club Polk!
    I originally did the Y adapter then I ended just using a single cable and plugged it into the left input.
    And saw no difference in sound.
    So I just ran a single cable from the my AVR preamp "subwoofer" output to the left input on the PSW10 until yesterday.
    Just picked up the Polk 505. I did however like the PSW10 more for music. Hope this helps
    You will be happy!
    Cheers!
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    Parasound 1200 II w/ Kimber Kable HERO + 4TC
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
    "If your BOLD enough to try it,
    your BOLD enough to make it happen"
  • Andrew R
    Andrew R Posts: 2
    quicksilvergts,
    Thanks for the help...everything seems to be running smoothly!
    I am always looking to upgrade, and the 505 did catch my attention, as it seems to be readily available anywhere online - with great reviews associated with it.
    I guess for now, the PSW10 will be more than adequate, because I'd say I use my whole system for music 70% of the time.
    Thanks again!
