looking at a couple subs...
nooshinjohn
looking at a couple in-wall subs for my audio room build...
http://www.ebay.com/itm/151227617030?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com/itm/Polk-Audio-CSW155-Passive-In-Wall-Subwoofer-Authorized-Dealer-New-in-Box-899-/161227478185?pt=Speakers_Subwoofers&hash=item2589e814a9
I am trying to decide which to go with, and one question popping up is what to use for powering them? I am thinking of getting a pair of 7 channel amps to power the system, so my thinking is that I should be able to pull a channel from one of them for this purpose.
The room size is 20 foot on the main wall by 15 feet deep.
Post edited by nooshinjohn on
OneCall also has the matching amp for the Sunfire HRS subs... But your 7 channel amps could probably handle these (assuming your taste for high powered amps will be used here).
http://www.ebay.com/itm/Sunfire-HRSIW8AMP-500-watt-Amplifier-Sunfire-HRSIW8CAB-/161224684623?pt=US_Home_Audio_Amplifiers_Preamps
As another option why not use a Dayton SA1000 at half the price?
Juan -
John....
How much depth do you have for subs? IIRC you have a false wall so why not just build your own? Or go with IB (Infinite Baffle) since you are using a converted garage?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »John....
The garage was converted to a room as the house was being built, they just did a crappy job doing it. I would rather go with one that is designed well for what I am looking to do. I am leaning towards the Sunfire because it has the two 8's and a system to reduce vibrations.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »The garage was converted to a room as the house was being built, they just did a crappy job doing it. I would rather go with one that is designed well for what I am looking to do. I am leaning towards the Sunfire because it has the two 8's and a system to reduce vibrations.
John, what I am saying is, do you have enough space to custom build your own sub in a Larger box so you can get it to dig lower and flatter than either of those in wall options.
IIRC there is a gap between your front wall and the actual front wall. Why not build your own box using that space since otherwise its just dead airspace."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »John, what I am saying is, do you have enough space to custom build your own sub in a Larger box so you can get it to dig lower and flatter than either of those in wall options.
The dead air space is a 6 foot deep by 20 foot long closet. The TV is centered on that wall, with the SRS on either side and then the doors to enter the closet on either side of those, so all use-able space on that wall is occupied. That leaves the ceiling, or the walls for the sub. I could just go with a powered sub and not build it into the walls but would rather have a clean aesthetic, as the room's primary reason to exist is still for two channel listening and I hate the look of a big box in the middle of the room.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »The dead air space is a 6 foot deep by 20 foot long closet. The TV is centered on that wall, with the SRS on either side and then the doors to enter the closet on either side of those, so all use-able space on that wall is occupied. That leaves the ceiling, or the walls for the sub. I could just go with a powered sub and not build it into the walls but would rather have a clean aesthetic, as the room's primary reason to exist is still for two channel listening and I hate the look of a big box in the middle of the room.
I gotcha. Thats what I was suggesting. Look at a Infinite baffle in the ceiling to use all that space as a box for the subs....... That would let it look just like you want, and you can get as much or little bass as you want.
http://www.avsforum.com/t/1250256/infinite-baffle-2-fi-ib3-18s-attic-manifold"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Wow, $600 for a couple of 8's..and you have 1.2's for mains, and you are still in the building stages of the room? Suprised you would want such small subs and not go the larger more custom route?
How about two, or four 12's, 15's firing at each other in a manifold? Should help reduce vibrations along with dampening the rear walls. Should at least consider IB...
Great Info:
http://home.comcast.net/~infinitelybaffled/
http://home.comcast.net/~infinitelybaffled/page2IB-Gallery.html
IB Talk:
http://www.youtube.com/watch?v=pPoblqaqhHg
Great drivers for IB
http://www.aespeakers.com/products.php
http://www.stereointegrity.com/
Great Pics:
https://www.google.com/search?q=infinite+baffle+manifold&safe=off&source=lnms&tbm=isch&sa=X&ei=zjAJU9COJoHCywH_xoDACw&ved=0CAoQ_AUoAg&biw=1366&bih=634
Could be as simple as this, $300 for two 15's and $200 for an amp.
Myself, If/when I ever get the space/dedicated room, that is what I will be doing.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
