Does it matter with subs that they match?
jasonb01
If your receiver supports 2 subs, would it matter much if the 2 subs match? Can one be a 12" and the other an 8". can one be front firing, and one down? I know the smaller one would not perform as well, but would you still be better off with the 2 mix-matched subs vs the one 12"?
TV: Panasonic TC-65PS64 65" Plasma
Receiver: Denon AVR-X4000
Blue-Ray: XBOX One
CD Player: Onkyo C-7030
Fronts: Polk Rti a5
Center: Polk Csi a6
Rears: Polk Rti a3
Sub: Polk DSW PRO660wi
Blue-Ray: XBOX One
Fronts: Polk Rti a5
Center: Polk Csi a6
Rears: Polk Rti a3
Post edited by jasonb01 on
You'll create a mess of bass waves doing that. If your going to use 2 subs, use 2 identical ones. Or just throw down for one really good sub.HT SYSTEM-
lsi 9's -
Gotcha....I figured as much, but wasn't sure. Thanks!TV: Panasonic TC-65PS64 65" Plasma
Blue-Ray: XBOX One
Fronts: Polk Rti a5
Center: Polk Csi a6
Rears: Polk Rti a3
Sub: Polk DSW PRO660wi -
Used to be that mixing subs was a no-no, but more people are doing it now with success. I'm running a Polk DSW Pro550 and 660 (10" and 12", though they are the same brand) and after spending some time with setup, they play together very nicely. Ideally, identical subs would still be the way to go, but don't discount being able to mix and match. I would maybe stick to sealed ( a general rule is they're more musical) or non-sealed (usually more HT friendly) with whatever you choose. Follow the sub forum over on AVS, there's lots of good info there.
I have 2 different subs the Boston sub is 10" and the DSW sub is 8". The DSW 400 goes a little lower than my Boston sub, but as Tornado says having the both of them on opposite sides of the room really help level the bass out. when I'm sitting in the sweet spot they sound great together.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Agreed Cathy. Rooms have their own characteristics, and one side is not likely the same as the other. I have a 7' opening to my 12' x 19' room at the back left of the sweet spot, my 12" sub is on that side since it's harder to pressurize with the opening than the other side which has no opening, and where the 10" resides. Anyway, good luck and happy listening with whatever you choose... -
I also run two in opposite corners of my room. While both Cerwin Vega CVT's one 15" one 12" works well for me. Mine are run a little different I use the 12" as a sub/satellite for my rears and the 15" as LFE.
^Do you do that because you don't have an output for the 2nd sub?
been using two different subs for years. never an issue as long as you calibrate correctly..
Tornado Red wrote: »Used to be that mixing subs was a no-no, but more people are doing it now with success. I'm running a Polk DSW Pro550 and 660 (10" and 12", though they are the same brand) and after spending some time with setup, they play together very nicely. Ideally, identical subs would still be the way to go, but don't discount being able to mix and match. I would maybe stick to sealed ( a general rule is they're more musical) or non-sealed (usually more HT friendly) with whatever you choose. Follow the sub forum over on AVS, there's lots of good info there.
should be fine just calibrate them so one does not bottom out before the other . I have seen setups where one sub was designed to do 20-60 hz and the other was 60-100 hertz .
A friend 3 subs and aura shakers , he likes it because the aura take the deep load off the subs . -
Having them identical is a heck of a lot easier. It can be done with mix and match but you probably better know what you're doing, meaning you're familiar with the science and aren't just a bass head. Mixing and matching ported vs. sealed is even harder.
Best paraphrased analogy I've heard is that its like taking your car and putting a snow tire on one wheel, mud tire on another, a drag slick on the third, and an all weather on the fourth, expecting great performance in all conditions, when in reality, you're just making it suck worse in all conditions than if you had just left it alone.
