Bhulley Boy Audio all handmade in Pakistan
There are so many questions to be asked about this 2 Mil system that I neglected before but worth asking now.
So, what's the weight and size of the speakers, the amp and the preamp?
What color options are available to order a set?
It looks like the speakers are 3 ways. So, is it passive only speaker with internal crossover or is it switchable to use with external active crossover?
What's the weight of these Tube amp and Preamp?
What are the Tube Complements?
The amps are SET or PP design? If it's PP design, is it UL or Triode operating in Class AB range or Triode Class A only?
Also, what is the nominal impedance of the speakers and the output tab on the amps output transformers (like 2,4,8, 16ohms)?
Is it available in 120V version or only 220-240V version?
Are the transformers made in house also? Is it Copper or Silver annealed wires?
Last question is how many sets have been sold and is there any set that is ready to sell or it's just made to order. If it's only made to order, what's the time frame for manufacturing and delivery?Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
With all those questions, simply call and ask. May have to brush up on your accent though.HT SYSTEM-
lsi 9's -
This thread is getting a little ridiculous. If interested call them - if not save the bandwith."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
drumminman wrote: »This thread is getting a little ridiculous. If interested call them - if not save the bandwith.
Just wondering you paid for any of the bandwidth because of your post doesn't provide any discussion in the thread either.
Why not say something instead? Good / Bad / Whatever?
We are enjoying the discussion about the "MOSTLY" hand made High Priced Audio. Nothing's been ridiculous about it.With all those questions, simply call and ask. May have to brush up on your accent though.
I hope it has the SPEC sheet posted somewhere on their websites and saved me an International call or popping up so many questions from my mind.
At the very least, they could have said something about the Wattage or Frequency Response.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Gorgeous stuff Jesse, thanks for posting.
Never knew they made sitars from gourds before either.Wristwatch--->Crisco -
Doubt that pal, why ? Limits the tire kickers. If you can afford their gear, an international call means zip.HT SYSTEM-
lsi 9's -
I got the impression this is "one of" type of thing, a prototype that can be used for various purposes, of which home audio is one possible use. Personally, I wouldn't bet any money it will ever be for sale.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Truthfully, I can't afford their asking price or 1/10th or 1/100th for that matter.
I didn't want to ask the price either or any other questions because it said right there "Don't Ask the Price, You can't afford it." So, I listened to their suggestion and never asked the price or the SPEC before.
As for International Calls, it's not the price. It's the efforts to make one or brush up my accent.I got the impression this is "one of" type of thing, a prototype that can be used for various purposes, of which home audio is one possible use. Personally, I wouldn't bet any money it will ever be for sale.
I am 99% sure that's the case!Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
In this case the only reason any need for a clean room would be for the fininshing of the wood. Guys at desks can put parts together very well and not need the modern necessities your talking about. I do like H9's analogy w/ hand made cars. Sure there are parts that are forged and then milled w/ lubricating oil all over the place but when it's time to assemble the thing it is built by hand and mostly all of it. Carbon fiber not so much but I degress.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
I enjoyed the posting, but not the back and forth about needing CAD, a clean room, etc. The thread degenerated into unproductive, silly speculation and argument."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
drumminman wrote: »I enjoyed the posting, but not the back and forth about needing CAD, a clean room, etc. The thread degenerated into unproductive, silly speculation and argument.
This is a bit confusing. I said CAD for the automotive industry and nothing related to Bhulley. Can you reread the posts where I mentioned about CAD?
Speculation? I made None of such things! I said "I don't know if they have the State of the Art facility hidden" somewhere in my post.
Do you have difficulty following my posts or do you selectively read only part of the texts from my posts?
If you have problem reading, just say so and I will quote you my post and post numbers for you.
Ar far as a clean room goes, I am not going to argue what you or F1 or Left think whether a clean room is necessary or what part is better produced in a clean room, etc.
It's a free world and everyone is entitled to their opinions.
It also depends on a people experiences in life. Some thinks finishing the wood cabinets for the speakers require a clean room but not for the electronics components. Some furniture experts thinks they are fine without a clean room. I think some electronics components is better made inside a clean room with proper tools.
You don't think none of this matters! So, who cares? I am not going to argue whether it matters or not with you. It's what you think and I think otherwise. It is unproductive to spend my time explaining why since I am pretty sure without some hands on experience or in a lab room which can be proven my theories, I can't explain it to you any further.
So, what's the big deal?
I said what I think and I am pretty darn sure no one can change that.
So, who the hell should argue who the hell for and for what? It's just opinions.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
I don't think they used CAD to design the Bhulley.Vinyl, the final frontier...
I don't know if Bhulley uses CAD or NOT.
But in my opinions, the hand made caps may come with any of these flavors for the enhanced listening pleasure - like sweet and sour, betel spicy (not to be confused with beetel) , cool mint or super hot and spicy.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
