SDA-2A VS RTA-12b
BKphoto
I will have both soon and my wife is going to kill me so one has to go...physically the 12's are in better shape...and I'm kind of leaning that way (peerless tweets) but want to hear what you guys have to say...money is not the worry I have less than 200 beans in both combined...
what say you...?
BK...
what say you...?
BK...
Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Post edited by BKphoto on
Never mind. I was thinking of a different model.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
I'd opt for the 2As, over the 12Bs, but I prefer SDA over conventional speakers. The 2As will be rather expensive to upgrade vs the 12Bs. The crossovers are more complex, and have some very large value capacitors. The 12Bs are not inexpensive to upgrade either, but not the same league as the 2As.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I liked SDA-12C's over SDA-2B's.
Not sure how different 12B's and 2A's are from the other letter versions but should be close.
If you like SDA and have room for proper setup, SDA.
If not, then 12B's have more midrange for my taste and are not that picky for placement.
I own both and prefer the 2A over just about any other speaker I currently own for pure listeniong pleasure. That said, if you have plenty of time to SIT and listen the 2A's are a no brainer here due to the SDA effect. However if most of your listening is not really sitting still in the sweet spot, I would opt for the 12's. SDA is useless outside the sweet spot, the 12's don't fall prey to this nearly as bad.
Or.... just ignore the wife and keep both. for the money you have in them you may want to switch them out from time to time or use them in different areas of the house. Give the wife an open door to buy herself something. That usually makes these things easier.If con is the opposite of pro, is Congress the opposite of Progress?!
Monitor 5Jr, Monitor 5, RTA12, RTA 15TL, SDA 2A, 1c, SRS 2, 1.2TL, CRS, Atrium. -
Mr. Bubbles wrote: »Or.... just ignore the wife and keep both. for the money you have in them you may want to switch them out from time to time or use them in different areas of the house. Give the wife an open door to buy herself something. That usually makes these things easier.
Great advice there, BK. Those are both large speaker pairs. A couple of questions to consider first, though: Is the garage big and comfortable? How cold does it get up there in garages in Westchester County? If no garage, how big/warm is the doghouse? -
teekay0007 wrote: »Great advice there, BK. Those are both large speaker pairs. A couple of questions to consider first, though: Is the garage big and comfortable? How cold does it get up there in garages in Westchester County? If no garage, how big/warm is the doghouse?
Now why would he put his wife in the garage or the doghouse? Hehe.
I have heard some people like the RTA12's better as they have a larger sweet spot than the SDA effect. -
hahaha....i agree with the keep both if i can swing that....
garage is cold....dont need to put drinks in the fridge cold...ha...i can sneak the 2A's down in the basement behind my photo set...then just act like the 12's are the 2A's "what do you mean dear those are the same ones" ha...
I think i'm going to do the 12's first...
one thing I have to find out that may have a say is this....I'm going to have my Hafler XL-280 converted to a musical concepts dual mono + their other goodies...Not sure this will still be a common ground amp or not...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
2As must have a common ground amp, and you cant use the AI-1, it will not work with the 3rd generation SDAshahaha....i agree with the keep both if i can swing that....
one thing I have to find out that may have a say is this....I'm going to have my Hafler XL-280 converted to a musical concepts dual mono + their other goodies...Not sure this will still be a common ground amp or not...Home Theater/2 Channel:
thats what i need to find out...what is the AI-1...?Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
sorry man but a little too over the edge for a $100 pair of 2A's
much easier to sell them or part them out if my amp isnt compatible after the mods...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
Knowing what I have learned here how limited you are w/ the SDA series I might not have jumped on them all that fast. But for $50 in the shape they were in I had to. Now the rap is front facing only, no tow in or out and no more of a spred of 8/9'.This is pretty limiting and I was lucky to have enough room for the placement of the 2Bs. If I now had my choice I still might go w/ Vandersteen 2ce sigs, Klipsch KLF 20s, or Fortes, or Ohm/Walsh 2or3xos. Even w/ my mirror imaged DCM TF 350s placed on the sides they still sound great.Logistics are a big consideration w/ SDA.
I think this was the shot I was going for. But the the SDA pix is a perfect spred w/ me at the couch at 9'.This is the shot I was going for showing the TF 350 left side and the ADC 303ax also left side of my living room.
our living room / listening room is a typical size, pretty big...
that being said I am leaning towards the 12's...
probably sell the 2A's or part them out if anyone interested in either...Between the 12's and the 10's I have plenty of speaker to choose from...plus i just got a pair of Infinity RSe's to go with my Marantz 1060 for my garage/mancave...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
Haven't heard 2A's but I have peerless 12B's and they are very good.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Me too. Great speakers! -
Have had the 2a's and 12b's and still have the 12c's enough said!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I have RTA 12c's with the usual mods. New caps and resistors, dynamat, hurricane nuts etc. I have used RDO 194's and the Peerless clones from Midwest Speaker in them. Not sure which tweeters I prefer yet. To mix it up a little more I just found a nice set of Peerless tweeters and I am going to put those in this evening to see how they sound. Overall they are a great sounding speaker.
Faustin, I didn't think you could swap 194s with Peerless tweeters. I thought the holes in the cabinets for them were different. Have you made modifications so both will work in your cabinets?
RTA12's don't have cutouts tweeter is attached to a plate in the top hat.. -
Ah yes. I had forgotten about those. I'm not sure why. I looked a a pair of those before I bought my 2Bs. Senior moment I guess.RTA12's don't have cutouts tweeter is attached to a plate in the top hat..
what was the question again?
Some have wire struts attaching them, while some have a molded fascia piece.RTA12's don't have cutouts tweeter is attached to a plate in the top hat..
yep i was thinking of the wire rod/strut set up when he said Peerless....
https://www.google.com/search?q=Polk+rta12&client=firefox-a&hs=e2h&rls=org.mozilla:en-US:official&channel=sb&source=lnms&tbm=isch&sa=X&ei=9Nj7UoTmFMHmqgH3jYEI&ved=0CAsQ_AUoAw&biw=1440&bih=794
top picture 2nd from left
I had thought (wrongly of course) that the fascia plate was already cut out for SL2000....leave it to Polk to prove me wrong once again:frown: -
They originally came with the sl-1000 tweeter. The RDO 194's don't sit flush like the sl-1000 or Peerless, and I had to drill a couple of small holes to screw them down. So they work but I personally do not like the way they fit, but I suppose it is more me because it is not perfect. -
westmassguy wrote: »Some have wire struts attaching them, while some have a molded fascia piece.
Dave are those my crossovers?????? -
Nope, you never sent me the tweeters.Home Theater/2 Channel:
Your right. I knew better than to send you a pair of Peerless. lol
You're the Peerless **** not me. I'll take my RDOs thank you very much.Home Theater/2 Channel:
Peerless ****???? I resemble that remark. I did put the Peerless in the 12's yesterday and I will be honest, it is hard to determine if the Peerless, the Peerless clones or the 194's sound better. I guess the only way to really tell is to have 2 or 3 sets of speakers side by side with different tweeters and be able to switch back and forth. I suppose having the original tweeter in a vintage speaker is part of the mystic.
