TL1 Satellite Speaker Driver Replacement
denisjanis
denisjanis Posts: 3
edited February 2014 in Speakers
Hi - I just purchased the TL1900 system and one of the satellite speakers had an issue with it. Polk is sending me a new driver to see if that may be the issue. I'm just wondering if anyone has some tips or instructions on how to change the driver on a TL1 satellite speaker. I am able to get the speaker grill off but from there I don't see any screws or anything else that I can remove to make the change. The driver is still on its way but was just curious if anyone had any tips on how this could be done? Seems like the hard plastic covering would need to be removed but I don't see how. Here is the product - http://www.polkaudio.com/products/tl1
Thanks for any help you can offer.
Post edited by denisjanis on
  • Hofy
    Hofy Posts: 169
    Check to see if the 4 rubber pieces that the grill posts go into come out. I think there maybe screws hiding under them. If there are just remove the screws and the 2 halves of the enclosure should come apart. The tweeter is most likely screwed into the front from behind. Good luck and keep us posted.
  • denisjanis
    denisjanis Posts: 3
    I will give that a shot. I tried a little with the rubber pieces but didn't get too aggressive because i thought they would tear apart. Thanks for the tip.
  • Hofy
    Hofy Posts: 169
    Polk may also include an instruction sheet with your replacement. Keep us up to date when you get the replacement.
  • denisjanis
    denisjanis Posts: 3
    I was able to get to the screws by removing the rubber stoppers. However, removing the rubber stoppers was a challenge because you can easily shred them to pieces trying to get them out. After taking a look at the inside and checking the connections and testing it out again, it appears to be working fine now but I will keep an eye (and ear) on it and replace the driver if needed.
  • Hofy
    Hofy Posts: 169
    Awesome news! Maybe Polk can send you some replacement rubber pieces.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    They're called "catch cups" and Polk should be able to provide you with replacements.
    Regards, Ken
