what have you done to scratch that itch to upgrade that didn't cost a lot?
marvda1
I've been knocking my head against the wall to do something about the itch to upgrade. the problem is I was all over the place on what to upgrade....cd player?preamp?power amp? the other problem is I'm at a point that to upgrade would cost a pretty penny. I had some Sylvania 12au7's for my belles 21a preamp that sounded great but were microphonic. I figured I would add something to my tube stash and went to ebay and grabbed a nos pair of Sylvania 12au7wa (6189) and low and behold the itch is gone and it cost less than $25. this one small change has brought new life to my system. speed, bass tightness and power,crystal clear sharp highs,better upper and mid detail. thought I was looking for more mid range warmth but the sylvanias are not as warm as the psvane 12au7-t that I had in before just clearer.
anyone else end up paying a lot less than you thought you would to get improvement in their system?
Puritan PSM156
Puritan PSM156
Post edited by marvda1 on
That's a tough one... Tube rolling is one way to go about it. I think that once the system has gone to a point where you seriously get to the point of diminishing returns, treating the room is the next best option. 600$ in bass trap is going to go a long way more than a speaker upgrade might in the bass dept.2Ch Tube Audio Convert
Swapped out the wall outlet, added Sorbothane isolation risers under gear, cleaned all electrical connections with Caig DeOxit and the next one is free. Remeasuring the speakers to make sure the tweeter height, toe in, levelness, distance from the wall, rake, distance to listening position are to within 2 to 3mm of where they need to be on all parameters.
Shut your rig down for two months and marvel at the improvements when you power it back up. Works like a charm.
George Grand wrote: »Shut your rig down for two months and marvel at the improvements when you power it back up. Works like a charm.
Winner, winner ................ chicken dinner!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
George makes a good point. Sometimes I go 2 weeks without turning it on then when I do it's like "damn, that sounds good".
The longer I listen consecutively, the more I start picking it apart....should I upgrade this...that. Then I open the old wallet and inside is a sticky note that says "WTF is wrong with you ?"HT SYSTEM-
lsi 9's -
OMG There is a man on here with common sense! The rest of you need to take a flea bath to control your itching!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Going thru your entire systems' cable management and improving it, is a good, cheap tweak. Keeping all AC and digital cables away from analog cables, etc.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Or just randomly unplug a few cables, maybe (maybe) clean the connections with a little emery cloth or a Q-tip moistened with DeOxit, and prepare to be astonished; jaw-dropping improvement.
(and, no, I am not being completely facetious)
This hifi upgrading is, to me, a lot like innovation. There's the evolutionary kind and the revolutinary kind. For innovation, companies claim to want the latter - but they really "only" want the former (I say this as a guy whose job for two years was "biotechnology technology innovation strategy" at a large pharmaceutical company).
For hifi, if one's current niche is monster-power class AB amplification, screaming (umm, I mean streaming) digital sources, DACs and low sensitivity loudspeakers - acquire or borrow a flea-powered single-ended direct heated triode amplifier and some high-sensitivty loudspeakers, or a turntable with a decent cartridge and preamp, and try another path to hifi enlightment. One might be stunned. -
Cookies ? Someone say Cookies ? HMMM....I'll PM you my addy.HT SYSTEM-
lsi 9's -
Puritan PSM156 -
smart @**. are you going to get both the pucks and cones?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
mhardy6647 wrote: »For hifi, if one's current niche is monster-power class AB amplification, screaming (umm, I mean streaming) digital sources, DACs and low sensitivity loudspeakers - acquire or borrow a flea-powered single-ended direct heated triode amplifier and some high-sensitivty loudspeakers, or a turntable with a decent cartridge and preamp, and try another path to hifi enlightment. One might be stunned.
With all due respect, some have and weren't.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I usually wipe the dust off the gears and speakers with a damp cloth and wipe clean with a micro fiber tower. It always sounded better after I am all done with the wiping dust. I am sure these dust creates more diffraction in the room. Likewise, removing the clutters in the audio room helps as well as vacuuming the carpets.
All cost almost next to nothing!Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
As long as they tried it fair and square, I'm good with that.SCompRacer wrote: »... some have and weren't.
Not sure why folks don't want to reveal the source of Bench Cookies...
http://woodworking.rockler.com/ppc/bench%20cookies?sli_sid=v9113&gclid=CLafpYCxwrwCFeYDOgodZEAAXg
(I like hockey pucks, FWIW - cheap and readily available new or used - at least in New England) -
Depends how much you're willing to change. I myself am in the middle of a net/net zero additional cash "upgrade". My plan is to replace my USB converter, DAC, and tube preamp with an all-in-one unit that costs less, then apply the saving + cost of my amp to a new tube amp or monos. Not positive that it will sound better, but it will certainly sound different, and I'll learn a lot in the process!
Here's what the before and after will look like:
Before:
USB Converter: Stello U3
DAC: Audio GD NFB-7
Preamp: Audio Research LS-15
Amp: BAT VK-500
After:
Pre/DAC: McIntosh D-100, Classe CP-800, or PS Audio PerfectWave mkii
Amp(s): ARC-VS115, BAT-VK75, Carver Cherry 180's, or other
I like that I'm going to a simpler solution. Hopefully it will sound better too!2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
I have been working on my 2 channel rig and currently looking for a turntable. I ran across this one.
https://app.audiogon.com/listings/turntables-turntable-ginga-kondo-ginga-2014-02-05-analog-italy-irwin-oh
It's a little outa my price range.:eek:HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC. -
Added Sorbothane isolation risers under gear, cleaned all electrical connections with Caig DeOxit and the next one is free. Remeasuring the speakers to make sure the tweeter height, toe in, levelness, distance from the wall, rake, distance to listening position are to within 2 to 3mm of where they need to be on all parameters.George Grand wrote: »Shut your rig down for two months and marvel at the improvements when you power it back up. Works like a charm.Going thru your entire systems' cable management and improving it, is a good, cheap tweak. Keeping all AC and digital cables away from analog cables, etc.Bench cookies are next on my list.
These are pretty much my first go-to tweaks before I start looking at gear. That means my system has to be settled enough from any gear changes for me to note/want to fix any inadeqacies.
Rather than bench cookies, I just have my dad (R&D chemist for Lilly) bring me home any of the industrial rubber tops from their larger beakers when they dont need them. They are QUITE good at dampening vibrations. I get all kinds of sizes, but normally in sets of 2 or 4
My next upgrade is going to be getting my last IC's and SC's fixed up. Then I am in deep debates about picking up a darblet for video. I have been busy addressing the audio portion (which my wife doesnt like as she keeps telling me she cant tell the diff). The Darblet is hopefully something that I can justify to her with actual A/B live testing and if we like it I might be able to spend "our" money rather than my small "upgrade" fund money which is VERY slow to acumulate
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Here are a couple other low-cost high-fun suggestions:
- Revisit speaker positioning (try some extremes... at the very least it'll be fun)
- Get some new music2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
I have a ton of those Rockler Bench Cookies in the shop! I'll have to try them underneath the Milwaukee Jobsite BoomBox and see if they improve the sound.DKG999
If I can't sit down and listen for at least an hour, the stuff doesn't get used. I won't trivialize my favorite tunes by ever using them as a background to whatever else I'm doing. Consequently, there can be long periods between listening sessions, and that keeps everything fresh.
I'm far too deaf now for anything to matter anyway, especially minor tweaks. -
Move the chair forward a few feet. Later move it back further. Then move it to back to the starting point.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I remember when I figured this one out. Sometimes the results of moving a chair 6-10" are astonishing.Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
HK AVR635 | Polk R30 | Sony DVD/SACD Player -
Cup your hands behind your ears costs nothing ! However make sure no one else is watching so you don't look like a chimpanzeeMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Bought a big bag of weed.
Dynamat is another cheap tweak that can really step up the level of detail in your rig.
And spikes.. -
George Grand wrote: »If I can't sit down and listen for at least an hour, the stuff doesn't get used. I won't trivialize my favorite tunes by ever using them as a background to whatever else I'm doing. Consequently, there can be long periods between listening sessions, and that keeps everything fresh.
George,
I love this answer. Something that we've always agreed on - music shouldn't be background noise to other goings on. I always try to find a time to just sit and listen - it doesn't happen often with work and family. I hope all is well with you :-)
James2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player -
Mikey081057 wrote: »Cup your hands behind your ears costs nothing ! However make sure no one else is watching so you don't look like a chimpanzee
I do that all the time, while looking over my shoulder sometimes it sounds better
you have done it, we will fasten some sort of ear cups tied to 3d glasses and no one will ever have to cup their ears again. -
Hookers and blow...
This is probably my favorite suggestion so far in the thread. Cable management in general, whether it be in a hi-fi system or in a high end computer rig, is generally overlooked and underrated.Going thru your entire systems' cable management and improving it, is a good, cheap tweak. Keeping all AC and digital cables away from analog cables, etc. -
I bought a used Parasound amp and pre-amp for $150, re-caped them for about $50. Bought NAP's LSi15 for $250. It is sweet.Stan
Main 2ch:
HT:
Other stuff:
