Where's my bass, Oh there it is...
FastGame
FastGame Posts: 67
edited January 2014 in Troubleshooting
I'm having a real problem with room acoustics and hopefully someone can help.
If I sit for normal listening (sofa, chair) my bass is weak to almost gone, floor level bass is totally gone even with sub woofer. Sitting position my ears are 43" from the floor, my speakers (borrowed set till my new one's come in) are 38" floor standing towers. If I stand up my ears are 67" from the floor and then the bass is nice and full...all one could ask for. I've tried 3 different set of speakers and still the same. Moving speakers closer or further from wall doesn't help much, further from wall is worst.
Any ideas on how to fix this acoustic problem ? I'm going to have around $ 10,000 in this system when I'm done and my wife (older irritated hen) is really on my A$$ about this, this is also wearing on my mind so I can't really blame the poor girl...
Thanks in advance.
Samsung PN64F8500, Parasound 2100 pre amp, Parasound 2250 v.2 amp, Parasound Zdac, OPPO 103D, Monitor Audio Silver RX8, Dual SVS PB 2000
Post edited by FastGame on
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2014
    have you done the sub crawl?
  • FastGame
    FastGame Posts: 67
    edited January 2014
    No, wasn't planing on using sub but if that's the only way to fix this then I'm making a big ($$$$) mistake on high end floor standers :( If I need to raise the floor or lower the ceiling 20" it would be a lot cheaper to get stand mounted monitors and sub.
    I just bought this house and didn't test stereo before purchase....looked like a normal room in a normal home to me, guess I was wrong.
    Toolfan66 Posts: 18,082
    edited January 2014
    What are you buying?
    2 channel, or HT?
    Room treatments?
  • recoveryone
    recoveryone Posts: 929
    edited January 2014
    could use more info on the room:
    Size
    Flooring
    Windows/or open spaces (hallways/opening to other rooms)
  • FastGame
    FastGame Posts: 67
    edited January 2014
    Toolfan66 wrote: »
    2 channel, or HT?
    Room treatments?
    From this thread http://www.polkaudio.com/forums/showthread.php?156894-Best-2.0-2.1-system-for-6-000
    FastGame wrote: »
    Update: I'm done.
    I didn't win the bid on the LEVINSON amp :(
    I bought a new Parasound Halo A23 http://www.parasound.com/halo/a23.php
    Parasound 2100 preamp http://www.parasound.com/nc/2100.php
    Parasound Zdac http://www.parasound.com/ParasoundZ/zdac.php
    Salk speakers http://www.salksound.com/songtower%20supercharged%20pricing.htm .
    Is this the best for the money ???...hmmm I don't know, so many dam choices...I know I could have done better going the used route but at my age I played it safe with new equipment.
    It's going to take 6 to 8 weeks to get the speakers built buy Salk, in the mean time my buddy is in Florida for the winter and he let me use his new Monitor Audio silver 8 speakers. My system sounds real sweet with them, I hope the Salks kick it up a notch...
    I don't know if I made a mistake on the DAC, it sounds fine, but maybe I should spent extra and got the Oppo 105 instead....hmmm so many choices.
    Thanks to all.
    Already have everything except the speakers plus I added the Oppo 105.
    I don't know anything about room treatments or where to start.
    Size
    Flooring
    1 long wall is picture window heavily draped, other long wall is half plaster and stone fire place. I will post pictures of the room later when I get home.
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2014
    You seriously need room treatments - absorber panels, bass traps, etc. Go to one of the manufacturer's website (GIK, ATS acoustics, Auralex, etc.) - they all provide a basic room analysis to tell you what kind of materials you need and where to place them. At least it will be a start.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
    mhardy6647 Posts: 35,060
    edited January 2014
  • Face
    Face Posts: 14,340
    edited January 2014
    Change your speaker placement drastically(use a different wall) or add multiple subs. Bass traps are inefficient and you would need many to fix your issue.
    You could buy all the best gear and speakers in the world and they wouldn't fix your bass issue.
    http://www.harman.com/EN-US/OurCompany/Innovation/Documents/White%20Papers/AES_Preprint_8748_color_plots.zip
  • CoolJazz
    CoolJazz Posts: 572
    edited January 2014
    Anytime somebody complains of very sharp peaks and valleys (all but gone thing) then my first instinct is to check the easy and free. Just make sure you're not wired out of phase.
    May not at all be it, but that's the basic first step before all the fine analysis and expense of what's where in the room and how many hard surfaces and what treatments etc.
    So just do the quick check as to the plus on the amp going to the plus on the speaker and the same on the other channel. Just to make sure this isn't that easy.....
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
    tonyb Posts: 33,072
    edited January 2014
    If you have the speakers in front of a heavily draped wall of windows, it will suck out your lower bass. The Songtowers are good speakers on their own, but they are not capable of going down to those lower bass notes like a sub can. You may have to add a subwoofer if your into bass heavy music or intend on using these for HT too. I think they are rated to go down to 35 hz, but that's in a perfect chamber, your own in room response will vary and most likely be in the 45 hz area.
    Also, could be you don't have the system calibrated ? Have you tinkered with the settings ? What cables are you using ?
  • FastGame
    FastGame Posts: 67
    edited January 2014
    ViperZ wrote: »
    I did as you suggested and found the solution. I got in the crawl space and insulated my floor with mineral wool and the bass is now the same sitting as it is standing...:) Next I will insulate the interior wall dividing the dining room from the living room, hopefully that will also help. I went to the Auralex site and studied how they built studio's, I don't have the money for that but I could try and get my wall's & floor done with the basic idea. http://www.acoustics101.com/common/figure3_1a.jpg
    Thanks to all for suggestions, I tried them all except the blender idea.....haha
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2014
    Glad it helped. You can build your own panels for fraction of the cost of professional panels. All you need is OFI 48 insulation material. Owens Corning 703 is the most popular brand name for OFI 48. Home-built panel usually costs about $50 compared to $200-300 professional one. All depends on your skill level on how well you will build the frame :)
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    treitz3 Posts: 20,019
    edited January 2014
    Have you tried raising the height of the speakers you are currently utilizing? Try [temporarily] grabbing a cinder block, bricks or even thick books to raise the height. Then sit down to listen. Any change in bass frequencies? Try to make for this experiment the tweeter height the same as your ears height at the sit down listening position. If the speakers are used, you may want to double check that the driver polarity hasn't been internally swapped.
