Headphone Amp For Computer Use?
msg
msg Posts: 10,479
edited February 2014 in Headphones
I'm looking for a headphone amp to use with my computer at the office. mostly just need something that will give me volume, bass and treble control. I've been using some speakers for years, but they're starting to give me some intermittent buzzing/clicking/popping. it's the speakers not the headphones, as I've check them plugged in directly to the computer headphone jack and they work okay.
Post edited by msg on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2014
    It all depends on how much you want to spend, for starters check out the Fiio E09 over on Amazon
    msg Posts: 10,479
    edited January 2014
    hmm. I'm looking for something with bass/treble controls. I don't see them on that one?
  • Libertyc
    Libertyc Posts: 915
    edited January 2014
  • AsSiMiLaTeD
    edited January 2014
    I'm fairly certain the Fiio has an EQ so should have the controls you want
    msg Posts: 10,479
    edited January 2014
    Libertyc wrote: »
    Never tried one but check it out.
    http://www.bravoaudio.com/bravo3.html
    hey, that looks pretty cool. a mini tube amp.
    I've been poking around a bit. seems like there's a bunch of these sort of things out there?
    man, I must be missing something. I'm just not seeing it.
  • WLDock
    WLDock Posts: 3,073
    edited January 2014
    Parts express has a nice selection all in one place:
    http://www.parts-express.com/cat/headphone-amplifiers/3445?N=11495%204294967118&Ne=10166&No=0&Nrpp=16&Nrs=collection()/record[endeca:matches(.,%22P_PortalID%22,%221%22)%20and%20endeca:matches(.,%22P_Searchable%22,%221%22)]&PortalID=1
  • sucks2beme
    sucks2beme Posts: 5,693
    edited January 2014
    If you are using PC based playback, shouldn't EQ be available at that level????
    I have the extended EQ running in Foobar and it works well.
    edited January 2014
    sucks2beme wrote: »
    Good point! I have the higher model Bravo amp, it has NO equalization even though it is their TOTL. Still pretty cheap though. If I have to equalize anything I do use PC software to do that, but most of the time EQ is unnecessary.
    Those Bravos are a lot of bang for the buck but they will get HOT and you have the option of changing out your tubes. They WILL power all but the MOST difficult loads fine and are pretty musical, tone down any digital brightness.
    cnh
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2014
    I am rolling this guy at work:
    http://www.ebay.ca/itm/MUSE-TU-20-EH6922-smallest-Tube-Preamp-Headphone-Amplifier-Sliver-/120940967370
    And most sound cards come with software, which has software equalizer.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • eeagle
    eeagle Posts: 226
    edited January 2014
    IMHO a DAC is the first requirement for improving PC sound. I would look for a DAC/AMP combo.
    Checkout my favoirte DAC/Amp available again now on Massdrop.com the Aune T!
    https://www.massdrop.com/buy/aune-t1-amp-dac-combo
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
    msg Posts: 10,479
    edited January 2014
    WLDock wrote: »
    yes, they do have a pretty wide selection!
    sucks2beme wrote: »
    I only have the basic soundcard that came with the computer; it doesn't seem to have any controls. I remember way back when you had to buy sound cards separately, they usually came with some bells and whistles and some blocky looking front end gui, heheh
    plus, I kinda like having knobs or sliders. was just curious.
    cnh wrote: »
    cnh
    which amp is this? from Parts Express? this one? If so, NICE!
    http://www.parts-express.com/bravo-audio-ocean-mini-valve-class-a-tube-headphone-amplifier--310-352
    ViperZ wrote: »
    that is NICE!
    I'll look again, I kinda just poked around quickly; it's an integrated sound card; nothing major. I've always just used the tone controls on my speakers with the headphone jack, but there's some weird intermittent buzzing/clicking/interference coming through now. not sure what's up with them.
    eeagle wrote: »
    man, that's a cool one, too.
    I think I have some old Creative Labs sound cards kicking around at the office. I remember some of them had 5.1 outputs, not that I'll need that for headphones. I'll have to see what they're all about. never paid much attention to them before.
  • j1mmy
    j1mmy Posts: 95
    The tube amps are very cool
  • AsSiMiLaTeD
    Fiio e07k or e17
