Headphone Amp For Computer Use?
msg
I'm looking for a headphone amp to use with my computer at the office. mostly just need something that will give me volume, bass and treble control. I've been using some speakers for years, but they're starting to give me some intermittent buzzing/clicking/popping. it's the speakers not the headphones, as I've check them plugged in directly to the computer headphone jack and they work okay.
It all depends on how much you want to spend, for starters check out the Fiio E09 over on Amazon
hmm. I'm looking for something with bass/treble controls. I don't see them on that one?I disabled signatures.
I'm fairly certain the Fiio has an EQ so should have the controls you want
hey, that looks pretty cool. a mini tube amp.Never tried one but check it out.
http://www.bravoaudio.com/bravo3.html
I've been poking around a bit. seems like there's a bunch of these sort of things out there?
man, I must be missing something. I'm just not seeing it.AsSiMiLaTeD wrote: »I'm fairly certain the Fiio has an EQ so should have the controls you wantI disabled signatures. -
Parts express has a nice selection all in one place:
http://www.parts-express.com/cat/headphone-amplifiers/3445?N=11495%204294967118&Ne=10166&No=0&Nrpp=16&Nrs=collection()/record[endeca:matches(.,%22P_PortalID%22,%221%22)%20and%20endeca:matches(.,%22P_Searchable%22,%221%22)]&PortalID=12.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3 -
If you are using PC based playback, shouldn't EQ be available at that level????
I have the extended EQ running in Foobar and it works well."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
sucks2beme wrote: »If you are using PC based playback, shouldn't EQ be available at that level????
Good point! I have the higher model Bravo amp, it has NO equalization even though it is their TOTL. Still pretty cheap though. If I have to equalize anything I do use PC software to do that, but most of the time EQ is unnecessary.
Those Bravos are a lot of bang for the buck but they will get HOT and you have the option of changing out your tubes. They WILL power all but the MOST difficult loads fine and are pretty musical, tone down any digital brightness.
I am rolling this guy at work:
http://www.ebay.ca/itm/MUSE-TU-20-EH6922-smallest-Tube-Preamp-Headphone-Amplifier-Sliver-/120940967370
And most sound cards come with software, which has software equalizer.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
IMHO a DAC is the first requirement for improving PC sound. I would look for a DAC/AMP combo.
Checkout my favoirte DAC/Amp available again now on Massdrop.com the Aune T!
https://www.massdrop.com/buy/aune-t1-amp-dac-comboSDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES -
yes, they do have a pretty wide selection!Parts express has a nice selection all in one place:
I only have the basic soundcard that came with the computer; it doesn't seem to have any controls. I remember way back when you had to buy sound cards separately, they usually came with some bells and whistles and some blocky looking front end gui, hehehsucks2beme wrote: »If you are using PC based playback, shouldn't EQ be available at that level????
plus, I kinda like having knobs or sliders. was just curious.
which amp is this? from Parts Express? this one? If so, NICE!Good point! I have the higher model Bravo amp, it has NO equalization even though it is their TOTL. Still pretty cheap though. If I have to equalize anything I do use PC software to do that, but most of the time EQ is unnecessary.
cnh
http://www.parts-express.com/bravo-audio-ocean-mini-valve-class-a-tube-headphone-amplifier--310-352
that is NICE!I am rolling this guy at work:
I'll look again, I kinda just poked around quickly; it's an integrated sound card; nothing major. I've always just used the tone controls on my speakers with the headphone jack, but there's some weird intermittent buzzing/clicking/interference coming through now. not sure what's up with them.
man, that's a cool one, too.IMHO a DAC is the first requirement for improving PC sound. I would look for a DAC/AMP combo.
I think I have some old Creative Labs sound cards kicking around at the office. I remember some of them had 5.1 outputs, not that I'll need that for headphones. I'll have to see what they're all about. never paid much attention to them before.I disabled signatures. -
The tube amps are very cool
Fiio e07k or e17
